Mitsubishi EVO8 2.0T mod 03
Postby 911rs » Sat Dec 05, 2009 8:28 pm
hi,
need to read / write via obd with my tactrix open port 2.0. could someone advise how to do :?: :idea:
regards
911rs
911rs
Re: Mitsubishi EVO8 2.0T mod 03
Postby todd-w » Sun Dec 06, 2009 7:20 am
with ecuflash / connect cable to obd port and white init connector ,switch ign on dont start ,from menu beside file select the blue download option ,in the drop down select evo8 and ok ,in the pop up window click ok . click on read image then save as , edit the title and save to whatever you wish for future ref .
then edit the rom when you want to write to the ecu , select the blue test write option follow the on screen instructions ,when thats done select the red write option again follow on screen instructions .
todd-w
Postby 911rs » Sun Dec 06, 2009 7:05 pm
thnx a lot todd-w :D
best regards
911rs
911rs
