02 Eclipse immobilizer delete needed
Postby meclipsegt » Thu Jun 25, 2009 5:20 pm
Im trying to swap in an 02 ECU into my 00 Eclipse, but Im having problems with the immobilizer delete. Ive tried the code for the Evos and it doesnt work. Can anyone help me out? Its XML 96720009 if that helps.
meclipsegt
Re: 02 Eclipse immobilizer delete needed
Postby acamus » Fri Jun 26, 2009 2:10 am
Either change 1 ecu periphery bit => not whole hex code 0xYYYY, or put immo hexcode from previous ecu to the current.
acamus
Postby meclipsegt » Fri Jun 26, 2009 10:16 pm
I could just swap the immobilizer code, but I need a definition for my 00 ROM then. Im attaching the 00 ROM, so if anyone can help me, it would be greatly appreciated.
00 ROM.hex
00 GT MT
(128 KiB) Downloaded 789 times
meclipsegt
Postby MattS00 » Sun Jun 28, 2009 9:53 am
Your rom ID is 21800023. It is located at address 1021a. I am not capable of dissassembling roms, so I just took an existing .xml for a 00 v6 eclipse. Looked up your rom ID and changed the rom ID in the .xml. The immobilizer code has not been found yet. Do you have a V6 eclipse?
21800023.xml
(3.85 KiB) Downloaded 794 times
MattS00
Postby acamus » Mon Jun 29, 2009 8:53 pm
It is because not many H8 ECU's had immo.
I believe the address is 2fece, unfortunately I cannot test it as I am not in possession of one.
meclipsegt please report back if it helped.
backup solution is to change periphery bits 0x52DE -> 0x52D6 in 96720009, but I would try value at 2fece first.
acamus
Postby meclipsegt » Mon Jun 29, 2009 10:38 pm
MattS00 wrote:Your rom ID is 21800023. It is located at address 1021a. I am not capable of dissassembling roms, so I just took an existing .xml for a 00 v6 eclipse. Looked up your rom ID and changed the rom ID in the .xml. The immobilizer code has not been found yet. Do you have a V6 eclipse?
Yeah, I have a V6 Eclipse.
Acamus, Ill try that on Thursday and see if it works. I know others have swapped the immobilizer code on the I4 Eclipses with success, so we will see.
Thanks for your help guys, its greatly appreciated. This ECU swap has been a headache for me.
meclipsegt
Postby meclipsegt » Thu Jul 02, 2009 11:08 pm
acamus wrote:It is because not many H8 ECU's had immo.
I tried both and they didnt work. Any other ideas?
I even compared the ECU pinouts and they were the same, its the autos that have problems. So Im lost now.
meclipsegt
Postby meclipsegt » Sun Jul 05, 2009 9:23 pm
I even tried swapping he ECU into an 01 Eclipse and it still didnt work.
meclipsegt
Postby acamus » Sun Jul 05, 2009 9:34 pm
The second option must work, where have you changed 0x52DE -> 0x52D6?
it should be at address FAA, can you send the ROM to me via email (PM sent)
acamus
Postby meclipsegt » Sun Jul 05, 2009 9:51 pm
Email sent. Thanks again.
meclipsegt
Postby meclipsegt » Mon Jul 06, 2009 12:12 pm
It didnt work, on mine or another V6. Is there any way to tell if the ECU is bad?
meclipsegt
Postby UMS Tuning » Tue Jul 14, 2009 10:09 am
I cant get one to work either 02 mt gt...any news/ideas?
Tony
UMS Tuning
Postby MattS00 » Tue Jul 14, 2009 10:31 am
The address of 2fece looks like it might be the right location for the immo code. I compared two 21810021 roms and the only differece was at 1fece and 1fecf.
Look at post 17.
http://geekmapped.com/forums/showthread ... 652&page=2
MattS00
