jdm sti 2003 cant interface
Postby Sc0oby » Tue Apr 07, 2009 5:17 pm
i recently converted a whole JDM sti 2003 into a GC8 body with all the wiring loom and guages all working properly. and since i follow all the instruction regarding the green connectors and the white jumper wire my laptop cant interface with the ECU. My OBD2 socket is working properly as i can diagnose it using a diagnostic tools.
Any ideas how i can interface with the ecu and reflash it?
Sc0oby
Re: jdm sti 2003 cant interface
Postby Sc0oby » Mon Apr 13, 2009 6:02 pm
am using tactrtic cable but still cant interface anyone has any ideas?? :(
Sc0oby
Postby west_minist » Tue Apr 21, 2009 5:56 am
dID YOU USE THE CLUTCH SWITCH?
I cannot remember if you need it.
Postby Sc0oby » Thu Apr 23, 2009 10:04 pm
nope old system does noty have the clutch switch
Sc0oby
Postby west_minist » Fri Apr 24, 2009 4:10 am
I will see if I can check today for a pull and see. I cannot remember using the clutch.
Make sure the jumpers are not damage. Do you hear clicking sounds when the read fails?
Postby MAVRIK Motorsports » Sun May 30, 2010 4:16 pm
Try clicking the read or flash icon, but don't have the key turned on yet, wait until it prompts you, then connect the green connector and turn the key on, and then press "ok". This has worked for me with a V8 JDM STi swap in a RS, worth a try.
Best regards,
Teddy
MAVRIK Motorsports
