Pls need Xml for 4G13 and 4G15 Mitsubishi Lancer
Postby sandy » Tue Apr 14, 2009 10:38 pm
Pls need Xml for 4G13 and 4G15 Mitsubishi Lancer. Thanks a lot!
lancer4G15.hex
(256 KiB) Downloaded 944 times
sandy
Re: Pls need Xml for 4G13 and 4G15 Mitsubishi Lancer
Postby acamus » Tue Apr 14, 2009 11:24 pm
ROMID = 92540005
ECU family = JM9254
SCC = E24D
Can you specify year?
I guess its Asian market.
Stock HP/Torque?
acamus
Postby sandy » Wed Apr 15, 2009 2:47 am
Yes JDM but bought in singapore. 4G13 year 02 and 4G15 year 04
sandy
Postby acamus » Wed Apr 15, 2009 3:12 am
I am not sure if both have the same ROM, if you will find that 4g13 has different ROM please post it.
What is specified as torque / horse power for this engine?
92540005.xml
(5.03 KiB) Downloaded 1044 times
acamus
Postby sandy » Wed Apr 15, 2009 3:50 am
Thanks for the file. I'll be trying it tonight.
I have no idea about its power or torque but
should be around 110hp.
Thanks again.
sandy
Postby sandy » Wed Apr 15, 2009 10:14 pm
The 4G13 is not same as the 4G15. Pls find attached file for 4G13.
Thanking you very much in advance.
4g13lancer.hex
(256 KiB) Downloaded 868 times
sandy
Postby acamus » Thu Apr 16, 2009 6:18 am
ROMID = 98510005
ECU family = EM9851
SCC = E235
98510005.xml
(4.54 KiB) Downloaded 998 times
acamus
Postby sandy » Fri Apr 17, 2009 7:40 am
Many many thanks to you acamus.
Hope to return the favour one of these days.
Actually working on the maps.
Thanks again.
sandy
Postby kc427 » Sun May 03, 2009 10:21 pm
I am interested to know how to read the 4G15 ROM from the Lancer? My friend has it, and I would like to read the ROM from it. Is it the same procedure as reading EVO roms?
kc427
Postby majin » Fri May 25, 2012 1:07 pm
acamus wrote:I am not sure if both have the same ROM, if you will find that 4g13 has different ROM please post it.
Is there a complete definition available? Need to find the fuel injector and MAP Sensor maps.
majin
