I have installed evo7 engine in a mitsubishi colt , and i use the stock ecu of this engine (MR560648). The engine dont start and as i belive the problem is the original immobiliser . I want to disable the immobiliser and i have seen that i need Tactrix OpenPort 2.0 for connecting to the ecu .I want to build myself the cable and the only schema that i found is for openport 1.3.
Can i use the OpenPort 1.3 for connecting to the ecu and disable the immobiliser?
Thanks!
