Can I flash different rom in my ecu?
Postby nipe » Sun Feb 01, 2009 9:56 pm
Hi, I'm new to all this so hopefully won't get flamed...I'm running evo 7 ecu with rom 98640014, what roms can I flash to my ecu instead of that one? And what does the rom number actually mean? Is this like a serial number? Thanks in advance.
nipe
Re: Can I flash different rom in my ecu?
Postby todd-w » Mon Feb 02, 2009 12:30 pm
ra rom 90550001 it can also have tephra mods
todd-w
Postby nipe » Mon Feb 02, 2009 2:53 pm
Oh thanks! So they exactly the same? Is 90550001 the newer version of 98640014?
nipe
Postby todd-w » Mon Feb 02, 2009 3:41 pm
its a ralliart version with tephra mods , it will need tuning ,,90550001 is the internal id of the rom
http://evoecu.logic.net/wiki/90550001
todd-w
Postby nipe » Tue Feb 03, 2009 12:47 am
Sorry if it's a stupid question, but couldn't seem to find more info on that: 2byte stuff, what is it and what is it used for? is it only used in evoscan to log? or it is used in ecu's also as a part of rom? And a bit off topic, I've done evo conversion on my lancer and am using evo 7 ecu, the thing is I couldn't find which ecu pin is used for manifold differential pressure sensor, so i used evo8 pin out and I think I connected it to pin13, now I get random values of boostMDP and jdm map in evoscan when logging, so i'm not sure if i used the right pin, could you please shed some light on this for me? If it's not too hard for you, thanks a lot for showing me the way around :)
nipe
Postby nipe » Tue Feb 03, 2009 1:07 am
Sorry it was pin73 not pin13. thanks
nipe
