help please!
help please!
Postby evansuka » Sat Dec 20, 2008 2:15 pm
I juste get my tactrix cable and try to use EcuFlash and EcuExplorer, i can use EcuExplorer to see data live but when i try to read ECU i can't
EcuFlash give me this:
Kernel get version
interface close
interface close
and EcuExplorer this:
Kernel flash disable
rkrv: preamble 1 no response
<< PROCESS COMPLTE >>
evansuka
Re: help please!
Postby pmugabi » Sun Dec 21, 2008 10:39 pm
Did you connect the green diagnostic connectors and jumper the flash block (if any)?
I had a similar problem last week after doing everything right. I read somewhere on here about low battery voltage causing such errors. So what I did was to connect the battery of a running car to the car being read/flashed using jumper cables. It then worked after about 2 minutes of the running car charging the one being read.
pmugabi
