crazymikie wrote:Thanks, Colby.
I've got two people interested in trying this right now- as soon as I get some feedback from them, I think I'd feel comfortable that it has been thoroughly tested.
May I make a suggestion?
Subaru has created a reflash for the 2004/5 which corrects a problem described as "Pinging during full throttle acceleration around 5000RPM" (see
http://forums.openecu.org/viewtopic.php?p=1998#1998). Chances are that your "delay" fix isn't based on the ROM CalIDs that incorporate the pinging fix. I don't recall that these SOA reflashes to fix pinging for the 2004/5 WRX have ever been discussed at NASIOC, so I conclude they're very rare in the wild.
I think it's very important, in the event you make your ROMs public, that you declare the CalIDs on which they're based, and that you recommend they not be installed when a user's CalID is higher. If a user has a higher CalID, he should, instead, be encouraged to publish his ROM image, so that your fix can be incorporated without loss of SOA's fixes. Ideally, your fix would be based on SOA's latest ROM.
For reference, here are the CalIDs which incorporate the 2004/5 WRX ping fix. Higher CalIDs for these models will include the ping fix because any newer SOA reflash is cummulative, incorporating fixes for all previous problems.
04 WRX MT - A4TF520F
04 WRX AT - A4TF520E
05 WRX MT - A4TF810F
05 WRX AT - A4TF810E
