Will ECUFlash v1.01.72 allow you to read an ECU ROM image from a JDM STI Spec C ECU?
Also, is there any software around that allows you to read the ROM image and show you the various maps the ECU is using?
mixja wrote:I attempted to read from the ECU, unfortunately it failed...
Car was set to USDM WRX 2002-2003. Using OpenPort 1.2 cable. Green test connectors were joined together.
Should the car do funny things with the test connectors attached? - the car fans kept turning on and off repeatedly in test mode...
NeverLies wrote:mixja wrote:I attempted to read from the ECU, unfortunately it failed...
This is the normal behavior when test mode is active. While Colby kernel is uploaded, fan should stop. What's your MY ? Have you been able to communicate with your car using for example ECUExplorer and your OpenPort ?
mixja wrote:
MY06 JDM STI Spec C Type RA. I can successfully connect with ECUExplorer no problems...
I'll try clicking OK first and then turning the ignition on, the software asks you to do it the other way round. If it still doesn't work, I'll try the cmd line version...
So your car should be a DBW and not yet supported except in monitoring mode.
Sorry, what is "DBW"? The ECU is a Denso ECU.
