Error connecting with Tactrix cable.
Postby diviniti » Thu Nov 06, 2008 3:47 pm
So I am sitting in my driveway on the laptop trying to figure out WTF my cable wont connect.
I have the newest version of ecuflash and I am trying to connect to my WRX.
Is it possible the cable I have is just for Mitsubishi and not for both Mitsu/Sub?
[18:05:59.533] Version 1.40.2178
[18:05:59.539] 19 memory models read.
[18:05:59.540] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[18:06:00.219] 319 ROM metadata models scanned.
[18:06:00.219] checksum module "subarudbw" loaded.
[18:06:00.219] flashing tool "wrx02" loaded.
[18:06:00.219] flashing tool "wrx04" loaded.
[18:06:00.219] flashing tool "sti04" loaded.
[18:06:00.220] flashing tool "sti05" loaded.
[18:06:00.220] flashing tool "mitsukernel" loaded.
[18:06:00.220] flashing tool "mitsukernelocp" loaded.
[18:06:00.220] flashing tool "shbootmode" loaded.
[18:06:00.604] flashing tool "shaudmode" loaded.
[18:06:00.604] flashing tool "subarucan" loaded.
[18:06:27.591] Using interface OpenPort 1.3b Mitsu TX38Fp2F689574d52d363644547ecd2aa395a374ad6bc2e0
[18:06:27.608] This vehicle interface does not support needed features.
[18:06:27.608] unable to connect to vehicle interface.
[18:06:27.608] interface close
diviniti
Re: Error connecting with Tactrix cable.
Postby Jon [in CT] » Fri Nov 07, 2008 11:06 am
diviniti wrote:Is it possible the cable I have is just for Mitsubishi and not for both Mitsu/Sub?
Correct. Your cable will only work with 32-bit Subaru ECUs and Mitsubishis.
Postby diviniti » Fri Nov 07, 2008 12:37 pm
I am going to take a stab in the dark here and assume that the 2004 WRX has a 16-Bit ECU?
I should have kept my other cable.
diviniti
Postby Jon [in CT] » Sat Nov 08, 2008 10:20 am
diviniti wrote:I am going to take a stab in the dark here and assume that the 2004 WRX has a 16-Bit ECU?
Yes, 2001-5 WRX models use a 16-bit ECU.
