Will it work on the UK300 ?
Postby Matt H » Fri Oct 31, 2008 11:27 pm
Hi guys,
Had an Impreza UK300 'bugeye' special edition in the other day. The Tactrix cable wouldn't read the ecu, but should it ?
The only strange thing is that this car had a Prodrive GEMS daughterboard installed inside the ECU. All this does is fools the map sensor so that you can run higher boost for a time period, but wondered if it would prevent the Tactrix cable\ECUFlash reading the ecu.
Should we be able to tune this car ?
It's one of these http://www.carfolio.com/specifications/ ... ?car=81620
Matt H
Postby radsdau » Sun Nov 02, 2008 4:04 pm
If it's a special, it's probably 'locked', i.e., the handshake protocol might have been modified. If that is the case, the Tactrix setup will not work.
Postby AndrewCarr » Mon Nov 03, 2008 6:23 am
Yes you should be able to map it, the MY01/02 PPP board only modifies the MAP and EGT signals.
If you couldn't read the ECU perhaps it already had an Ecutek ROM on it?
Andrew...
AndrewCarr
Postby Matt H » Mon Nov 03, 2008 10:45 am
You are spot on about the PPP board mate, just MAP and EGT.
Maybe I will try again with the Tactrix lead, I know connection is sometimes 'shakey'.
If it's locked then I guess it could be ECUTEK'd.
Matt :)
Matt H
Postby Matt H » Tue Nov 18, 2008 1:48 pm
Had the car in again today, but couldn't connect at all. The ecu is a V3, isn't that off of the classic shape STis ? Very odd.
Matt H
