by todd-w » Fri Oct 10, 2008 3:42 pm
im running my 4 on 7 ecu for the past yr or more , using ra rom 90550001
rad and ac fan wires need to be changed
you need to make a few pin changes in the ecu plugs
take out pin 20 and put it into 32
take out pin 21 and put it into 34
32 and 34 have no pins in the plug on 4 ecu
you also need a pin to go into 79 and run a wire from this to the white init socket on ecuflash cable to flash ecu.
theres are two evo 7 ecu,s if its the later one part no starting with MN you need to swap pins 8 and 22 ,thats fuel pump and a/c comp relay.
you need to disable the front o2 heater circuit in the rom periphery or wire a 4 wire o2 sensor to your car, if you wire in a 4 wire sensor you need switched 12v to one heater wire and the other heater circuit wire goes to pin 60 again the evo4 doesnt have a pin in the plug as the 4 uses a 2 wire sensor with no heater.
use evo5/6/7 560 cc injectors and the 4 maf sensor then you shouldnt have to play with inj or maf scaling ,, you could swap the cams for evo 5/6/7 ones but its not essential,,i wouldnt run more than 1.2/1.3 bar boost on evo4 std internals
if you send me an e-mail addy i can send you the std ra rom ready to go,but you will HAVE to tune it .
