EcuFlash 1.38 + OP2.0 Is not flashing 08 STi
Postby mdonohoe » Wed Oct 08, 2008 9:48 pm
Btw, the pigs fly comment was a joke. I'm a Cobol/SQL Developer and more than understand what the DEV guys on this project must be going thru.
mdonohoe
Postby mdonohoe » Thu Oct 09, 2008 6:33 pm
Hooray, ECUFLASH 1.39 is out!
mdonohoe
Postby hmanxx » Thu Oct 09, 2008 11:00 pm
are you going to test write ?
hmanxx
Postby mdonohoe » Thu Oct 09, 2008 11:01 pm
Hello,
Just tried with the new version, seems to be AOK, can anybody confirm? The initial failed starts seemed to be due to me turning the key at the wrong point. Who knows.
TEST Flash mode only...
[16:49:21.253] Version 1.39.2152
[16:49:21.253] 19 memory models read.
[16:49:21.253] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[16:49:25.652] 318 ROM metadata models scanned.
[16:49:25.652] checksum module "subarudbw" loaded.
[16:49:25.652] flashing tool "wrx02" loaded.
[16:49:25.652] flashing tool "wrx04" loaded.
[16:49:25.652] flashing tool "sti04" loaded.
[16:49:25.652] flashing tool "sti05" loaded.
[16:49:25.652] flashing tool "mitsukernel" loaded.
[16:49:25.652] flashing tool "mitsukernelocp" loaded.
[16:49:25.652] flashing tool "shbootmode" loaded.
[16:49:25.746] flashing tool "shaudmode" loaded.
[16:49:25.746] flashing tool "subarucan" loaded.
[16:49:36.847] AZ1E400C (255 tables) inheriting 32BITBASE (662 tables)
[16:49:36.940] 1048576 byte image read.
[16:53:03.498] J2534 API Version: 04.04
[16:53:03.498] J2534 DLL Version: 0.50.2150 Oct 9 2008 12:45:03
[16:53:03.498] Device Firmware Version: 1.01.2145
[16:53:06.155] interface close
[16:53:41.258] J2534 API Version: 04.04
[16:53:41.258] J2534 DLL Version: 0.50.2150 Oct 9 2008 12:45:03
[16:53:41.258] Device Firmware Version: 1.01.2145
[16:53:49.751] kernel get version
[16:53:50.016] SSM2 init
[16:53:50.068] SSM2 ECU ID is 51 52 58 40 07
[16:53:50.104] Requesting Seed...
[16:53:50.167] Sending Key...
[16:53:50.743] interface close
[16:53:50.797] interface close
[16:53:57.324] J2534 API Version: 04.04
[16:53:57.324] J2534 DLL Version: 0.50.2150 Oct 9 2008 12:45:03
[16:53:57.324] Device Firmware Version: 1.01.2145
[16:53:59.461] kernel get version
[16:53:59.708] SSM2 init
[16:53:59.969] interface close
[16:54:00.021] interface close
[16:54:09.027] J2534 API Version: 04.04
[16:54:09.027] J2534 DLL Version: 0.50.2150 Oct 9 2008 12:45:03
[16:54:09.027] Device Firmware Version: 1.01.2145
[16:54:10.602] kernel get version
[16:54:10.859] SSM2 init
[16:54:10.926] SSM2 ECU ID is 51 52 58 40 07
[16:54:10.948] Requesting Seed...
[16:54:10.991] Sending Key...
[16:54:13.384] kernel get version
[16:54:13.406] kernel version is : OpenECU Subaru SH7058 OCP CAN Kernel V1.06
[16:54:13.406] reading kernel comm buffer size
[16:54:13.428] comm buffer size set to 2048
[16:54:13.428] reading kernel flash buffer size
[16:54:13.451] flash buffer size set to 4096
[16:54:13.451] Test flashing image to ECU memory...
[16:54:13.851] comparing ECU flash memory pages to image file
[16:54:13.851] seg start len ecu CRC32 img CRC32 same?
[16:54:13.873] FB01 00000000 00001000 3019EEFC 3019EEFC YES
[16:54:13.905] FB02 00001000 00001000 750D1713 750D1713 YES
[16:54:13.937] FB03 00002000 00001000 804C543D 804C543D YES
[16:54:13.971] FB04 00003000 00001000 304BCC1F 304BCC1F YES
[16:54:13.992] FB05 00004000 00001000 53A157C9 53A157C9 YES
[16:54:14.015] FB06 00005000 00001000 0644E9D6 0644E9D6 YES
[16:54:14.055] FB07 00006000 00001000 AA4FE5DD AA4FE5DD YES
[16:54:14.082] FB08 00007000 00001000 259EEE33 259EEE33 YES
[16:54:14.226] FB09 00008000 00018000 6036A298 6036A298 YES
[16:54:14.408] FB10 00020000 00020000 8D11C606 8D11C606 YES
[16:54:14.590] FB11 00040000 00020000 5FF1A74A 5FF1A74A YES
[16:54:14.776] FB12 00060000 00020000 5F6E70B5 5F6E70B5 YES
[16:54:14.969] FB13 00080000 00020000 018F14E4 018F14E4 YES
[16:54:15.168] FB14 000A0000 00020000 DF1BA44A DF1BA44A YES
[16:54:15.350] FB15 000C0000 00020000 D5F196D1 52D997DD NO
[16:54:15.547] FB16 000E0000 00020000 951764ED 4CBD4702 NO
[16:54:15.549] kernel flash disable
[16:54:15.583] kernel write flash buffer addr: 000FF000 len: 00000800
[16:54:15.701] kernel write flash buffer addr: 000FF800 len: 00000800
[16:54:15.818] kernel validate flash addr: 000FF000 len: 00001000 crc32: a8a123c4
[16:54:15.839] kernel write flash buffer addr: 000C0000 len: 00000800
[16:54:15.945] kernel write flash buffer addr: 000C0800 len: 00000800
[16:54:16.059] kernel validate flash addr: 000C0000 len: 00001000 crc32: 44515c51
[16:54:16.080] kernel write flash buffer addr: 000C1000 len: 00000800
[16:54:16.194] kernel write flash buffer addr: 000C1800 len: 00000800
[16:54:16.312] kernel validate flash addr: 000C1000 len: 00001000 crc32: e07abb2f
[16:54:16.351] kernel write flash buffer addr: 000C2000 len: 00000800
[16:54:16.469] kernel write flash buffer addr: 000C2800 len: 00000800
[16:54:16.585] kernel validate flash addr: 000C2000 len: 00001000 crc32: 123337f7
[16:54:16.606] kernel write flash buffer addr: 000C3000 len: 00000800
[16:54:16.719] kernel write flash buffer addr: 000C3800 len: 00000800
[16:54:16.835] kernel validate flash addr: 000C3000 len: 00001000 crc32: 58b54caf
[16:54:16.856] kernel write flash buffer addr: 000C4000 len: 00000800
[16:54:16.961] kernel write flash buffer addr: 000C4800 len: 00000800
[16:54:17.075] kernel validate flash addr: 000C4000 len: 00001000 crc32: 0bed06ba
[16:54:17.100] kernel write flash buffer addr: 000C5000 len: 00000800
[16:54:17.219] kernel write flash buffer addr: 000C5800 len: 00000800
[16:54:17.334] kernel validate flash addr: 000C5000 len: 00001000 crc32: 4fb0b701
[16:54:17.356] kernel write flash buffer addr: 000C6000 len: 00000800
[16:54:17.472] kernel write flash buffer addr: 000C6800 len: 00000800
[16:54:17.587] kernel validate flash addr: 000C6000 len: 00001000 crc32: c5e505d2
[16:54:17.610] kernel write flash buffer addr: 000C7000 len: 00000800
[16:54:17.726] kernel write flash buffer addr: 000C7800 len: 00000800
[16:54:17.840] kernel validate flash addr: 000C7000 len: 00001000 crc32: da3526bf
[16:54:17.876] kernel write flash buffer addr: 000C8000 len: 00000800
[16:54:17.992] kernel write flash buffer addr: 000C8800 len: 00000800
[16:54:18.108] kernel validate flash addr: 000C8000 len: 00001000 crc32: 3c51caab
[16:54:18.129] kernel write flash buffer addr: 000C9000 len: 00000800
[16:54:18.245] kernel write flash buffer addr: 000C9800 len: 00000800
[16:54:18.361] kernel validate flash addr: 000C9000 len: 00001000 crc32: 02656dd5
[16:54:18.399] kernel write flash buffer addr: 000CA000 len: 00000800
[16:54:18.516] kernel write flash buffer addr: 000CA800 len: 00000800
[16:54:18.632] kernel validate flash addr: 000CA000 len: 00001000 crc32: 89303eb2
[16:54:18.653] kernel write flash buffer addr: 000CB000 len: 00000800
[16:54:18.768] kernel write flash buffer addr: 000CB800 len: 00000800
[16:54:18.883] kernel validate flash addr: 000CB000 len: 00001000 crc32: 94050582
[16:54:18.920] kernel write flash buffer addr: 000CC000 len: 00000800
[16:54:19.034] kernel write flash buffer addr: 000CC800 len: 00000800
[16:54:19.148] kernel validate flash addr: 000CC000 len: 00001000 crc32: a5065965
[16:54:19.169] kernel write flash buffer addr: 000CD000 len: 00000800
[16:54:19.284] kernel write flash buffer addr: 000CD800 len: 00000800
[16:54:19.398] kernel validate flash addr: 000CD000 len: 00001000 crc32: 6b87849d
[16:54:19.434] kernel write flash buffer addr: 000CE000 len: 00000800
[16:54:19.550] kernel write flash buffer addr: 000CE800 len: 00000800
[16:54:19.669] kernel validate flash addr: 000CE000 len: 00001000 crc32: b2f76765
[16:54:19.690] kernel write flash buffer addr: 000CF000 len: 00000800
[16:54:19.806] kernel write flash buffer addr: 000CF800 len: 00000800
[16:54:19.909] kernel validate flash addr: 000CF000 len: 00001000 crc32: 9068538c
[16:54:19.949] kernel write flash buffer addr: 000D0000 len: 00000800
[16:54:20.065] kernel write flash buffer addr: 000D0800 len: 00000800
[16:54:20.179] kernel validate flash addr: 000D0000 len: 00001000 crc32: 862d05cb
[16:54:20.200] kernel write flash buffer addr: 000D1000 len: 00000800
[16:54:20.314] kernel write flash buffer addr: 000D1800 len: 00000800
[16:54:20.435] kernel validate flash addr: 000D1000 len: 00001000 crc32: b82462dc
[16:54:20.461] kernel write flash buffer addr: 000D2000 len: 00000800
[16:54:20.574] kernel write flash buffer addr: 000D2800 len: 00000800
[16:54:20.689] kernel validate flash addr: 000D2000 len: 00001000 crc32: b68814a5
[16:54:20.710] kernel write flash buffer addr: 000D3000 len: 00000800
[16:54:20.816] kernel write flash buffer addr: 000D3800 len: 00000800
[16:54:20.932] kernel validate flash addr: 000D3000 len: 00001000 crc32: 9205dfa7
[16:54:20.953] kernel write flash buffer addr: 000D4000 len: 00000800
[16:54:21.075] kernel write flash buffer addr: 000D4800 len: 00000800
[16:54:21.180] kernel validate flash addr: 000D4000 len: 00001000 crc32: 75975234
[16:54:21.201] kernel write flash buffer addr: 000D5000 len: 00000800
[16:54:21.317] kernel write flash buffer addr: 000D5800 len: 00000800
[16:54:21.425] kernel validate flash addr: 000D5000 len: 00001000 crc32: 106b1a96
[16:54:21.446] kernel write flash buffer addr: 000DC000 len: 00000800
[16:54:21.566] kernel write flash buffer addr: 000DC800 len: 00000800
[16:54:21.679] kernel validate flash addr: 000DC000 len: 00001000 crc32: c2ac9d18
[16:54:21.716] kernel write flash buffer addr: 000DD000 len: 00000800
[16:54:21.820] kernel write flash buffer addr: 000DD800 len: 00000800
[16:54:21.928] kernel validate flash addr: 000DD000 len: 00001000 crc32: 55a3c6c5
[16:54:21.965] kernel write flash buffer addr: 000DF000 len: 00000800
[16:54:22.071] kernel write flash buffer addr: 000DF800 len: 00000800
[16:54:22.195] kernel validate flash addr: 000DF000 len: 00001000 crc32: ff43226b
[16:54:22.231] kernel flash disable
[16:54:22.252] verifying result...
[16:54:22.252] comparing ECU flash memory pages to image file
[16:54:22.252] seg start len ecu CRC32 img CRC32 same?
[16:54:22.286] FB01 00000000 00001000 3019EEFC 3019EEFC YES
[16:54:22.307] FB02 00001000 00001000 750D1713 750D1713 YES
[16:54:22.340] FB03 00002000 00001000 804C543D 804C543D YES
[16:54:22.367] FB04 00003000 00001000 304BCC1F 304BCC1F YES
[16:54:22.405] FB05 00004000 00001000 53A157C9 53A157C9 YES
[16:54:22.431] FB06 00005000 00001000 0644E9D6 0644E9D6 YES
[16:54:22.469] FB07 00006000 00001000 AA4FE5DD AA4FE5DD YES
[16:54:22.505] FB08 00007000 00001000 259EEE33 259EEE33 YES
[16:54:22.664] FB09 00008000 00018000 6036A298 6036A298 YES
[16:54:22.862] FB10 00020000 00020000 8D11C606 8D11C606 YES
[16:54:23.051] FB11 00040000 00020000 5FF1A74A 5FF1A74A YES
[16:54:23.252] FB12 00060000 00020000 5F6E70B5 5F6E70B5 YES
[16:54:23.451] FB13 00080000 00020000 018F14E4 018F14E4 YES
[16:54:23.640] FB14 000A0000 00020000 DF1BA44A DF1BA44A YES
[16:54:23.839] FB15 000C0000 00020000 D5F196D1 52D997DD NO
[16:54:24.037] FB16 000E0000 00020000 951764ED 4CBD4702 NO
[16:54:24.065] interface close
[16:54:24.133] interface close
[16:54:37.736] J2534 API Version: 04.04
[16:54:37.736] J2534 DLL Version: 0.50.2150 Oct 9 2008 12:45:03
[16:54:37.736] Device Firmware Version: 1.01.2145
[16:54:40.415] kernel get version
[16:54:40.458] kernel version is : OpenECU Subaru SH7058 OCP CAN Kernel V1.06
[16:54:40.458] reading kernel comm buffer size
[16:54:40.479] comm buffer size set to 2048
[16:54:40.479] reading kernel flash buffer size
[16:54:40.510] flash buffer size set to 4096
[16:54:40.510] Test flashing image to ECU memory...
[16:54:40.910] comparing ECU flash memory pages to image file
[16:54:40.910] seg start len ecu CRC32 img CRC32 same?
[16:54:40.941] FB01 00000000 00001000 3019EEFC 3019EEFC YES
[16:54:40.973] FB02 00001000 00001000 750D1713 750D1713 YES
[16:54:41.007] FB03 00002000 00001000 804C543D 804C543D YES
[16:54:41.042] FB04 00003000 00001000 304BCC1F 304BCC1F YES
[16:54:41.076] FB05 00004000 00001000 53A157C9 53A157C9 YES
[16:54:41.110] FB06 00005000 00001000 0644E9D6 0644E9D6 YES
[16:54:41.142] FB07 00006000 00001000 AA4FE5DD AA4FE5DD YES
[16:54:41.174] FB08 00007000 00001000 259EEE33 259EEE33 YES
[16:54:41.327] FB09 00008000 00018000 6036A298 6036A298 YES
[16:54:41.509] FB10 00020000 00020000 8D11C606 8D11C606 YES
[16:54:41.691] FB11 00040000 00020000 5FF1A74A 5FF1A74A YES
[16:54:41.873] FB12 00060000 00020000 5F6E70B5 5F6E70B5 YES
[16:54:42.065] FB13 00080000 00020000 018F14E4 018F14E4 YES
[16:54:42.259] FB14 000A0000 00020000 DF1BA44A DF1BA44A YES
[16:54:42.442] FB15 000C0000 00020000 D5F196D1 52D997DD NO
[16:54:42.623] FB16 000E0000 00020000 951764ED 4CBD4702 NO
[16:54:42.623] kernel flash disable
[16:54:42.645] kernel write flash buffer addr: 000FF000 len: 00000800
[16:54:42.765] kernel write flash buffer addr: 000FF800 len: 00000800
[16:54:42.882] kernel validate flash addr: 000FF000 len: 00001000 crc32: a8a123c4
[16:54:42.904] kernel write flash buffer addr: 000C0000 len: 00000800
[16:54:43.019] kernel write flash buffer addr: 000C0800 len: 00000800
[16:54:43.134] kernel validate flash addr: 000C0000 len: 00001000 crc32: 44515c51
[16:54:43.155] kernel write flash buffer addr: 000C1000 len: 00000800
[16:54:43.271] kernel write flash buffer addr: 000C1800 len: 00000800
[16:54:43.388] kernel validate flash addr: 000C1000 len: 00001000 crc32: e07abb2f
[16:54:43.410] kernel write flash buffer addr: 000C2000 len: 00000800
[16:54:43.526] kernel write flash buffer addr: 000C2800 len: 00000800
[16:54:43.643] kernel validate flash addr: 000C2000 len: 00001000 crc32: 123337f7
[16:54:43.665] kernel write flash buffer addr: 000C3000 len: 00000800
[16:54:43.781] kernel write flash buffer addr: 000C3800 len: 00000800
[16:54:43.897] kernel validate flash addr: 000C3000 len: 00001000 crc32: 58b54caf
[16:54:43.929] kernel write flash buffer addr: 000C4000 len: 00000800
[16:54:44.036] kernel write flash buffer addr: 000C4800 len: 00000800
[16:54:44.152] kernel validate flash addr: 000C4000 len: 00001000 crc32: 0bed06ba
[16:54:44.186] kernel write flash buffer addr: 000C5000 len: 00000800
[16:54:44.303] kernel write flash buffer addr: 000C5800 len: 00000800
[16:54:44.417] kernel validate flash addr: 000C5000 len: 00001000 crc32: 4fb0b701
[16:54:44.449] kernel write flash buffer addr: 000C6000 len: 00000800
[16:54:44.566] kernel write flash buffer addr: 000C6800 len: 00000800
[16:54:44.672] kernel validate flash addr: 000C6000 len: 00001000 crc32: c5e505d2
[16:54:44.706] kernel write flash buffer addr: 000C7000 len: 00000800
[16:54:44.825] kernel write flash buffer addr: 000C7800 len: 00000800
[16:54:44.942] kernel validate flash addr: 000C7000 len: 00001000 crc32: da3526bf
[16:54:44.976] kernel write flash buffer addr: 000C8000 len: 00000800
[16:54:45.093] kernel write flash buffer addr: 000C8800 len: 00000800
[16:54:45.211] kernel validate flash addr: 000C8000 len: 00001000 crc32: 3c51caab
[16:54:45.244] kernel write flash buffer addr: 000C9000 len: 00000800
[16:54:45.348] kernel write flash buffer addr: 000C9800 len: 00000800
[16:54:45.465] kernel validate flash addr: 000C9000 len: 00001000 crc32: 02656dd5
[16:54:45.488] kernel write flash buffer addr: 000CA000 len: 00000800
[16:54:45.607] kernel write flash buffer addr: 000CA800 len: 00000800
[16:54:45.715] kernel validate flash addr: 000CA000 len: 00001000 crc32: 89303eb2
[16:54:45.738] kernel write flash buffer addr: 000CB000 len: 00000800
[16:54:45.854] kernel write flash buffer addr: 000CB800 len: 00000800
[16:54:45.962] kernel validate flash addr: 000CB000 len: 00001000 crc32: 94050582
[16:54:45.984] kernel write flash buffer addr: 000CC000 len: 00000800
[16:54:46.098] kernel write flash buffer addr: 000CC800 len: 00000800
[16:54:46.212] kernel validate flash addr: 000CC000 len: 00001000 crc32: a5065965
[16:54:46.235] kernel write flash buffer addr: 000CD000 len: 00000800
[16:54:46.341] kernel write flash buffer addr: 000CD800 len: 00000800
[16:54:46.456] kernel validate flash addr: 000CD000 len: 00001000 crc32: 6b87849d
[16:54:46.488] kernel write flash buffer addr: 000CE000 len: 00000800
[16:54:46.605] kernel write flash buffer addr: 000CE800 len: 00000800
[16:54:46.723] kernel validate flash addr: 000CE000 len: 00001000 crc32: b2f76765
[16:54:46.746] kernel write flash buffer addr: 000CF000 len: 00000800
[16:54:46.854] kernel write flash buffer addr: 000CF800 len: 00000800
[16:54:46.960] kernel validate flash addr: 000CF000 len: 00001000 crc32: 9068538c
[16:54:46.982] kernel write flash buffer addr: 000D0000 len: 00000800
[16:54:47.099] kernel write flash buffer addr: 000D0800 len: 00000800
[16:54:47.214] kernel validate flash addr: 000D0000 len: 00001000 crc32: 862d05cb
[16:54:47.236] kernel write flash buffer addr: 000D1000 len: 00000800
[16:54:47.345] kernel write flash buffer addr: 000D1800 len: 00000800
[16:54:47.463] kernel validate flash addr: 000D1000 len: 00001000 crc32: b82462dc
[16:54:47.485] kernel write flash buffer addr: 000D2000 len: 00000800
[16:54:47.599] kernel write flash buffer addr: 000D2800 len: 00000800
[16:54:47.713] kernel validate flash addr: 000D2000 len: 00001000 crc32: b68814a5
[16:54:47.735] kernel write flash buffer addr: 000D3000 len: 00000800
[16:54:47.860] kernel write flash buffer addr: 000D3800 len: 00000800
[16:54:47.966] kernel validate flash addr: 000D3000 len: 00001000 crc32: 9205dfa7
[16:54:47.987] kernel write flash buffer addr: 000D4000 len: 00000800
[16:54:48.095] kernel write flash buffer addr: 000D4800 len: 00000800
[16:54:48.214] kernel validate flash addr: 000D4000 len: 00001000 crc32: 75975234
[16:54:48.248] kernel write flash buffer addr: 000D5000 len: 00000800
[16:54:48.359] kernel write flash buffer addr: 000D5800 len: 00000800
[16:54:48.476] kernel validate flash addr: 000D5000 len: 00001000 crc32: 106b1a96
[16:54:48.508] kernel write flash buffer addr: 000DC000 len: 00000800
[16:54:48.649] kernel write flash buffer addr: 000DC800 len: 00000800
[16:54:48.756] kernel validate flash addr: 000DC000 len: 00001000 crc32: c2ac9d18
[16:54:48.789] kernel write flash buffer addr: 000DD000 len: 00000800
[16:54:48.896] kernel write flash buffer addr: 000DD800 len: 00000800
[16:54:49.012] kernel validate flash addr: 000DD000 len: 00001000 crc32: 55a3c6c5
[16:54:49.033] kernel write flash buffer addr: 000DF000 len: 00000800
[16:54:49.143] kernel write flash buffer addr: 000DF800 len: 00000800
[16:54:49.262] kernel validate flash addr: 000DF000 len: 00001000 crc32: ff43226b
[16:54:49.294] kernel flash disable
[16:54:49.325] verifying result...
[16:54:49.325] comparing ECU flash memory pages to image file
[16:54:49.325] seg start len ecu CRC32 img CRC32 same?
[16:54:49.356] FB01 00000000 00001000 3019EEFC 3019EEFC YES
[16:54:49.377] FB02 00001000 00001000 750D1713 750D1713 YES
[16:54:49.408] FB03 00002000 00001000 804C543D 804C543D YES
[16:54:49.429] FB04 00003000 00001000 304BCC1F 304BCC1F YES
[16:54:49.457] FB05 00004000 00001000 53A157C9 53A157C9 YES
[16:54:49.492] FB06 00005000 00001000 0644E9D6 0644E9D6 YES
[16:54:49.525] FB07 00006000 00001000 AA4FE5DD AA4FE5DD YES
[16:54:49.546] FB08 00007000 00001000 259EEE33 259EEE33 YES
[16:54:49.690] FB09 00008000 00018000 6036A298 6036A298 YES
[16:54:49.871] FB10 00020000 00020000 8D11C606 8D11C606 YES
[16:54:50.053] FB11 00040000 00020000 5FF1A74A 5FF1A74A YES
[16:54:50.237] FB12 00060000 00020000 5F6E70B5 5F6E70B5 YES
[16:54:50.424] FB13 00080000 00020000 018F14E4 018F14E4 YES
[16:54:50.615] FB14 000A0000 00020000 DF1BA44A DF1BA44A YES
[16:54:50.812] FB15 000C0000 00020000 D5F196D1 52D997DD NO
[16:54:50.994] FB16 000E0000 00020000 951764ED 4CBD4702 NO
[16:54:51.025] interface close
[16:54:51.084] interface close
mdonohoe
Postby mgv101 » Fri Oct 10, 2008 5:46 am
Just did a test write and a real flash with the new version. Worked perfectly for me.
mgv101
Postby SonnyCosworth » Fri Oct 10, 2008 5:52 am
Flashed success.. :lol:[/img]
Last edited by SonnyCosworth on Fri Oct 10, 2008 10:17 am, edited 1 time in total.
SonnyCosworth
Postby hmanxx » Fri Oct 10, 2008 9:44 am
did you guys get an automatic firmware update of OP 2.0 on first time clicking of Test write button on Ecuflash v1.39 ?.
I did a test write after OP2.0 Firmware update. it completed successfully without error as log below..
[17:02:32.375] Version 1.39.2152
[17:02:32.390] 19 memory models read.
[17:02:32.390] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[17:02:32.531] 318 ROM metadata models scanned.
[17:02:32.531] checksum module "subarudbw" loaded.
[17:02:32.531] flashing tool "wrx02" loaded.
[17:02:32.531] flashing tool "wrx04" loaded.
[17:02:32.531] flashing tool "sti04" loaded.
[17:02:32.531] flashing tool "sti05" loaded.
[17:02:32.531] flashing tool "mitsukernel" loaded.
[17:02:32.531] flashing tool "mitsukernelocp" loaded.
[17:02:32.531] flashing tool "shbootmode" loaded.
[17:02:32.531] flashing tool "shaudmode" loaded.
[17:02:32.531] flashing tool "subarucan" loaded.
[17:02:40.140] AZ1E400C (255 tables) inheriting 32BITBASE (662 tables)
[17:02:40.187] 1048576 byte image read.
[17:02:47.218] J2534 API Version: 04.04
[17:02:47.218] J2534 DLL Version: 0.50.2150 Oct  9 2008 12:45:03
[17:02:47.218] Device Firmware Version: 1.01.2145
[17:02:54.593] kernel get version
[17:02:55.015] SSM2 init
[17:02:55.078] SSM2 ECU ID is 51 52 58 40 07
[17:02:55.109] Requesting Seed...
[17:02:55.187] Sending Key...
[17:02:58.171] kernel get version
[17:02:58.203] kernel version is : OpenECU Subaru SH7058 OCP CAN Kernel V1.06
[17:02:58.203] reading kernel comm buffer size
[17:02:58.250] comm buffer size set to 2048
[17:02:58.250] reading kernel flash buffer size
[17:02:58.296] flash buffer size set to 4096
[17:02:58.296] Test flashing image to ECU memory...
[17:02:58.703] comparing ECU flash memory pages to image file
[17:02:58.703] seg  start    len        ecu CRC32    img CRC32  same?
[17:02:58.734] FB01 00000000 00001000   3019EEFC     3019EEFC     YES
[17:02:58.781] FB02 00001000 00001000   750D1713     750D1713     YES
[17:02:58.812] FB03 00002000 00001000   804C543D     804C543D     YES
[17:02:58.859] FB04 00003000 00001000   304BCC1F     304BCC1F     YES
[17:02:58.906] FB05 00004000 00001000   53A157C9     53A157C9     YES
[17:02:58.937] FB06 00005000 00001000   0644E9D6     0644E9D6     YES
[17:02:58.984] FB07 00006000 00001000   AA4FE5DD     AA4FE5DD     YES
[17:02:59.031] FB08 00007000 00001000   259EEE33     259EEE33     YES
[17:02:59.187] FB09 00008000 00018000   6036A298     6036A298     YES
[17:02:59.375] FB10 00020000 00020000   8D11C606     8D11C606     YES
[17:02:59.562] FB11 00040000 00020000   5FF1A74A     5FF1A74A     YES
[17:02:59.765] FB12 00060000 00020000   5F6E70B5     5F6E70B5     YES
[17:02:59.953] FB13 00080000 00020000   018F14E4     018F14E4     YES
[17:03:00.156] FB14 000A0000 00020000   DF1BA44A     DF1BA44A     YES
[17:03:00.359] FB15 000C0000 00020000   D5F196D1     BE39D790      NO
[17:03:00.562] FB16 000E0000 00020000   951764ED     4CBD4702      NO
[17:03:00.562] kernel flash disable
[17:03:00.593] kernel write flash buffer addr: 000FF000 len: 00000800
[17:03:00.734] kernel write flash buffer addr: 000FF800 len: 00000800
[17:03:00.875] kernel validate flash addr: 000FF000 len: 00001000 crc32: a8a123c4
[17:03:00.921] kernel write flash buffer addr: 000C0000 len: 00000800
[17:03:01.046] kernel write flash buffer addr: 000C0800 len: 00000800
[17:03:01.156] kernel validate flash addr: 000C0000 len: 00001000 crc32: cb929cdc
[17:03:01.203] kernel write flash buffer addr: 000C1000 len: 00000800
[17:03:01.328] kernel write flash buffer addr: 000C1800 len: 00000800
[17:03:01.453] kernel validate flash addr: 000C1000 len: 00001000 crc32: 582677db
[17:03:01.484] kernel write flash buffer addr: 000C2000 len: 00000800
[17:03:01.609] kernel write flash buffer addr: 000C2800 len: 00000800
[17:03:01.734] kernel validate flash addr: 000C2000 len: 00001000 crc32: 123337f7
[17:03:01.765] kernel write flash buffer addr: 000C3000 len: 00000800
[17:03:01.890] kernel write flash buffer addr: 000C3800 len: 00000800
[17:03:02.015] kernel validate flash addr: 000C3000 len: 00001000 crc32: 58b54caf
[17:03:02.062] kernel write flash buffer addr: 000C4000 len: 00000800
[17:03:02.187] kernel write flash buffer addr: 000C4800 len: 00000800
[17:03:02.312] kernel validate flash addr: 000C4000 len: 00001000 crc32: 0bed06ba
[17:03:02.343] kernel write flash buffer addr: 000C5000 len: 00000800
[17:03:02.453] kernel write flash buffer addr: 000C5800 len: 00000800
[17:03:02.578] kernel validate flash addr: 000C5000 len: 00001000 crc32: 4fb0b701
[17:03:02.625] kernel write flash buffer addr: 000C6000 len: 00000800
[17:03:02.765] kernel write flash buffer addr: 000C6800 len: 00000800
[17:03:02.890] kernel validate flash addr: 000C6000 len: 00001000 crc32: ca22fda9
[17:03:02.937] kernel write flash buffer addr: 000C7000 len: 00000800
[17:03:03.078] kernel write flash buffer addr: 000C7800 len: 00000800
[17:03:03.203] kernel validate flash addr: 000C7000 len: 00001000 crc32: adbcb71b
[17:03:03.250] kernel write flash buffer addr: 000C8000 len: 00000800
[17:03:03.375] kernel write flash buffer addr: 000C8800 len: 00000800
[17:03:03.500] kernel validate flash addr: 000C8000 len: 00001000 crc32: 002f029c
[17:03:03.546] kernel write flash buffer addr: 000C9000 len: 00000800
[17:03:03.656] kernel write flash buffer addr: 000C9800 len: 00000800
[17:03:03.796] kernel validate flash addr: 000C9000 len: 00001000 crc32: 02656dd5
[17:03:03.843] kernel write flash buffer addr: 000CA000 len: 00000800
[17:03:03.953] kernel write flash buffer addr: 000CA800 len: 00000800
[17:03:04.078] kernel validate flash addr: 000CA000 len: 00001000 crc32: 49434b73
[17:03:04.109] kernel write flash buffer addr: 000CB000 len: 00000800
[17:03:04.234] kernel write flash buffer addr: 000CB800 len: 00000800
[17:03:04.359] kernel validate flash addr: 000CB000 len: 00001000 crc32: 25d9bfb3
[17:03:04.390] kernel write flash buffer addr: 000CC000 len: 00000800
[17:03:04.515] kernel write flash buffer addr: 000CC800 len: 00000800
[17:03:04.640] kernel validate flash addr: 000CC000 len: 00001000 crc32: a5065965
[17:03:04.687] kernel write flash buffer addr: 000CD000 len: 00000800
[17:03:04.812] kernel write flash buffer addr: 000CD800 len: 00000800
[17:03:04.937] kernel validate flash addr: 000CD000 len: 00001000 crc32: 285413a3
[17:03:04.968] kernel write flash buffer addr: 000CE000 len: 00000800
[17:03:05.093] kernel write flash buffer addr: 000CE800 len: 00000800
[17:03:05.203] kernel validate flash addr: 000CE000 len: 00001000 crc32: f8678ee0
[17:03:05.234] kernel write flash buffer addr: 000CF000 len: 00000800
[17:03:05.359] kernel write flash buffer addr: 000CF800 len: 00000800
[17:03:05.484] kernel validate flash addr: 000CF000 len: 00001000 crc32: 3ab00359
[17:03:05.515] kernel write flash buffer addr: 000D0000 len: 00000800
[17:03:05.656] kernel write flash buffer addr: 000D0800 len: 00000800
[17:03:05.796] kernel validate flash addr: 000D0000 len: 00001000 crc32: 862d05cb
[17:03:05.843] kernel write flash buffer addr: 000D1000 len: 00000800
[17:03:05.968] kernel write flash buffer addr: 000D1800 len: 00000800
[17:03:06.093] kernel validate flash addr: 000D1000 len: 00001000 crc32: 1145cbb9
[17:03:06.140] kernel write flash buffer addr: 000D2000 len: 00000800
[17:03:06.265] kernel write flash buffer addr: 000D2800 len: 00000800
[17:03:06.390] kernel validate flash addr: 000D2000 len: 00001000 crc32: a060fd71
[17:03:06.437] kernel write flash buffer addr: 000D3000 len: 00000800
[17:03:06.562] kernel write flash buffer addr: 000D3800 len: 00000800
[17:03:06.703] kernel validate flash addr: 000D3000 len: 00001000 crc32: 9205dfa7
[17:03:06.734] kernel write flash buffer addr: 000D4000 len: 00000800
[17:03:06.859] kernel write flash buffer addr: 000D4800 len: 00000800
[17:03:06.984] kernel validate flash addr: 000D4000 len: 00001000 crc32: ed8a8fee
[17:03:07.015] kernel write flash buffer addr: 000D5000 len: 00000800
[17:03:07.156] kernel write flash buffer addr: 000D5800 len: 00000800
[17:03:07.296] kernel validate flash addr: 000D5000 len: 00001000 crc32: 28dd7656
[17:03:07.343] kernel write flash buffer addr: 000DC000 len: 00000800
[17:03:07.484] kernel write flash buffer addr: 000DC800 len: 00000800
[17:03:07.609] kernel validate flash addr: 000DC000 len: 00001000 crc32: 0e8209c1
[17:03:07.656] kernel write flash buffer addr: 000DD000 len: 00000800
[17:03:07.781] kernel write flash buffer addr: 000DD800 len: 00000800
[17:03:07.906] kernel validate flash addr: 000DD000 len: 00001000 crc32: 321794ed
[17:03:07.937] kernel write flash buffer addr: 000DF000 len: 00000800
[17:03:08.078] kernel write flash buffer addr: 000DF800 len: 00000800
[17:03:08.218] kernel validate flash addr: 000DF000 len: 00001000 crc32: ff43226b
[17:03:08.250] kernel flash disable
[17:03:08.296] verifying result...
[17:03:08.296] comparing ECU flash memory pages to image file
[17:03:08.296] seg  start    len        ecu CRC32    img CRC32  same?
[17:03:08.328] FB01 00000000 00001000   3019EEFC     3019EEFC     YES
[17:03:08.359] FB02 00001000 00001000   750D1713     750D1713     YES
[17:03:08.406] FB03 00002000 00001000   804C543D     804C543D     YES
[17:03:08.437] FB04 00003000 00001000   304BCC1F     304BCC1F     YES
[17:03:08.468] FB05 00004000 00001000   53A157C9     53A157C9     YES
[17:03:08.515] FB06 00005000 00001000   0644E9D6     0644E9D6     YES
[17:03:08.562] FB07 00006000 00001000   AA4FE5DD     AA4FE5DD     YES
[17:03:08.593] FB08 00007000 00001000   259EEE33     259EEE33     YES
[17:03:08.750] FB09 00008000 00018000   6036A298     6036A298     YES
[17:03:08.953] FB10 00020000 00020000   8D11C606     8D11C606     YES
[17:03:09.140] FB11 00040000 00020000   5FF1A74A     5FF1A74A     YES
[17:03:09.343] FB12 00060000 00020000   5F6E70B5     5F6E70B5     YES
[17:03:09.546] FB13 00080000 00020000   018F14E4     018F14E4     YES
[17:03:09.750] FB14 000A0000 00020000   DF1BA44A     DF1BA44A     YES
[17:03:09.953] FB15 000C0000 00020000   D5F196D1     BE39D790      NO
[17:03:10.156] FB16 000E0000 00020000   951764ED     4CBD4702      NO
[17:03:10.187] interface close
[17:03:10.265] interface close
hmanxx
Postby mdonohoe » Fri Oct 10, 2008 7:08 pm
Bit the bullet, parked the car where I knew that I could leave it if it all went bad. Did a test write, went OK, did a REAL write, went aok :-)
MY08 WRX(Delivered 10/07) 2.5L MT flashed today. Local Australian Model.
Yes, the firmware upgraded. Didnt work at first. I then used a VISTA(ewww) machine just to get it to upgrade. Then all was ok.
mdonohoe
Postby hmanxx » Fri Oct 10, 2008 10:28 pm
oops..the car i did test write has same Internal ID as Australian model..thanks for the status update..
hmanxx
who know XML file for X
Postby Fueltank-Tai » Sat Oct 11, 2008 8:48 am
Fueltank-Tai
Postby cboles » Sat Oct 11, 2008 1:37 pm
Anyone who is stuck with a non-responsive ECU from 1.38 - please get in touch with me at support@tactrix.com so we can fix your ECU for you.
Re: who know XML file for X
Postby mdonohoe » Sat Oct 11, 2008 10:57 pm
Fueltank-Tai wrote:who know XML file for X
What do you mean?
mdonohoe
Postby hmanxx » Mon Oct 13, 2008 6:24 pm
Successfully reflashing EDM MY08 LegacyGT, A2UG001G
[00:56:39.671] Version 1.39.2152
[00:56:39.687] 19 memory models read.
[00:56:39.687] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[00:56:39.843] 318 ROM metadata models scanned.
[00:56:39.843] checksum module "subarudbw" loaded.
[00:56:39.843] flashing tool "wrx02" loaded.
[00:56:39.843] flashing tool "wrx04" loaded.
[00:56:39.843] flashing tool "sti04" loaded.
[00:56:39.843] flashing tool "sti05" loaded.
[00:56:39.843] flashing tool "mitsukernel" loaded.
[00:56:39.843] flashing tool "mitsukernelocp" loaded.
[00:56:39.843] flashing tool "shbootmode" loaded.
[00:56:39.843] flashing tool "shaudmode" loaded.
[00:56:39.843] flashing tool "subarucan" loaded.
[00:57:02.921] A2UG001G (262 tables) inheriting 32BITBASE (662 tables)
[00:57:02.968] 1048576 byte image read.
[00:57:19.421] J2534 API Version: 04.04
[00:57:19.421] J2534 DLL Version: 0.50.2150 Oct  9 2008 12:45:03
[00:57:19.421] Device Firmware Version: 1.01.2145
[00:57:24.093] kernel get version
[00:57:24.500] SSM2 init
[00:57:24.562] SSM2 ECU ID is 4B 52 50 41 07
[00:57:24.609] Requesting Seed...
[00:57:24.703] Sending Key...
[00:57:27.562] kernel get version
[00:57:27.593] kernel version is : OpenECU Subaru SH7058 OCP CAN Kernel V1.06
[00:57:27.593] reading kernel comm buffer size
[00:57:27.640] comm buffer size set to 2048
[00:57:27.640] reading kernel flash buffer size
[00:57:27.687] flash buffer size set to 4096
[00:57:27.687] Test flashing image to ECU memory...
[00:57:28.093] comparing ECU flash memory pages to image file
[00:57:28.093] seg  start    len        ecu CRC32    img CRC32  same?
[00:57:28.125] FB01 00000000 00001000   0B9158D5     0B9158D5     YES
[00:57:28.156] FB02 00001000 00001000   EA035F4B     EA035F4B     YES
[00:57:28.203] FB03 00002000 00001000   45CE543F     45CE543F     YES
[00:57:28.250] FB04 00003000 00001000   B585C9DF     B585C9DF     YES
[00:57:28.296] FB05 00004000 00001000   B5A95EAB     B5A95EAB     YES
[00:57:28.328] FB06 00005000 00001000   3A1F0459     3A1F0459     YES
[00:57:28.375] FB07 00006000 00001000   C90AB7B9     C90AB7B9     YES
[00:57:28.406] FB08 00007000 00001000   89F5D89F     89F5D89F     YES
[00:57:28.671] FB09 00008000 00018000   15019EFD     15019EFD     YES
[00:57:29.031] FB10 00020000 00020000   920B1059     920B1059     YES
[00:57:29.390] FB11 00040000 00020000   596AD159     596AD159     YES
[00:57:29.750] FB12 00060000 00020000   D61A2B44     D61A2B44     YES
[00:57:30.125] FB13 00080000 00020000   FAFC2FB3     FAFC2FB3     YES
[00:57:30.500] FB14 000A0000 00020000   AE59A32B     AE59A32B     YES
[00:57:30.875] FB15 000C0000 00020000   8B062089     36439BE1      NO
[00:57:31.250] FB16 000E0000 00020000   4E07494B     E12BF0E9      NO
[00:57:31.250] kernel flash disable
[00:57:31.296] kernel write flash buffer addr: 000FF000 len: 00000800
[00:57:31.437] kernel write flash buffer addr: 000FF800 len: 00000800
[00:57:31.562] kernel validate flash addr: 000FF000 len: 00001000 crc32: 0537942f
[00:57:31.609] kernel write flash buffer addr: 000C0000 len: 00000800
[00:57:31.734] kernel write flash buffer addr: 000C0800 len: 00000800
[00:57:31.859] kernel validate flash addr: 000C0000 len: 00001000 crc32: 5d882503
[00:57:31.906] kernel write flash buffer addr: 000C1000 len: 00000800
[00:57:32.031] kernel write flash buffer addr: 000C1800 len: 00000800
[00:57:32.156] kernel validate flash addr: 000C1000 len: 00001000 crc32: aefb11f8
[00:57:32.218] kernel write flash buffer addr: 000C2000 len: 00000800
[00:57:32.343] kernel write flash buffer addr: 000C2800 len: 00000800
[00:57:32.468] kernel validate flash addr: 000C2000 len: 00001000 crc32: 64de5462
[00:57:32.500] kernel write flash buffer addr: 000C3000 len: 00000800
[00:57:32.609] kernel write flash buffer addr: 000C3800 len: 00000800
[00:57:32.718] kernel validate flash addr: 000C3000 len: 00001000 crc32: c552b6ff
[00:57:32.765] kernel write flash buffer addr: 000C4000 len: 00000800
[00:57:32.890] kernel write flash buffer addr: 000C4800 len: 00000800
[00:57:33.015] kernel validate flash addr: 000C4000 len: 00001000 crc32: 1f7d9e81
[00:57:33.062] kernel write flash buffer addr: 000C5000 len: 00000800
[00:57:33.187] kernel write flash buffer addr: 000C5800 len: 00000800
[00:57:33.312] kernel validate flash addr: 000C5000 len: 00001000 crc32: 22115aab
[00:57:33.359] kernel write flash buffer addr: 000C6000 len: 00000800
[00:57:33.484] kernel write flash buffer addr: 000C6800 len: 00000800
[00:57:33.609] kernel validate flash addr: 000C6000 len: 00001000 crc32: c24bba73
[00:57:33.640] kernel write flash buffer addr: 000C7000 len: 00000800
[00:57:33.750] kernel write flash buffer addr: 000C7800 len: 00000800
[00:57:33.875] kernel validate flash addr: 000C7000 len: 00001000 crc32: d8dcea8c
[00:57:33.906] kernel write flash buffer addr: 000C8000 len: 00000800
[00:57:34.031] kernel write flash buffer addr: 000C8800 len: 00000800
[00:57:34.156] kernel validate flash addr: 000C8000 len: 00001000 crc32: 58afc290
[00:57:34.203] kernel write flash buffer addr: 000C9000 len: 00000800
[00:57:34.328] kernel write flash buffer addr: 000C9800 len: 00000800
[00:57:34.453] kernel validate flash addr: 000C9000 len: 00001000 crc32: 5d18c549
[00:57:34.500] kernel write flash buffer addr: 000CA000 len: 00000800
[00:57:34.625] kernel write flash buffer addr: 000CA800 len: 00000800
[00:57:34.750] kernel validate flash addr: 000CA000 len: 00001000 crc32: cc25cd8f
[00:57:34.781] kernel write flash buffer addr: 000CB000 len: 00000800
[00:57:34.906] kernel write flash buffer addr: 000CB800 len: 00000800
[00:57:35.031] kernel validate flash addr: 000CB000 len: 00001000 crc32: 0ed5a482
[00:57:35.078] kernel write flash buffer addr: 000CC000 len: 00000800
[00:57:35.203] kernel write flash buffer addr: 000CC800 len: 00000800
[00:57:35.328] kernel validate flash addr: 000CC000 len: 00001000 crc32: 9f48d077
[00:57:35.375] kernel write flash buffer addr: 000CD000 len: 00000800
[00:57:35.500] kernel write flash buffer addr: 000CD800 len: 00000800
[00:57:35.625] kernel validate flash addr: 000CD000 len: 00001000 crc32: 097e1777
[00:57:35.671] kernel write flash buffer addr: 000CE000 len: 00000800
[00:57:35.796] kernel write flash buffer addr: 000CE800 len: 00000800
[00:57:35.921] kernel validate flash addr: 000CE000 len: 00001000 crc32: fd6d9774
[00:57:35.968] kernel write flash buffer addr: 000CF000 len: 00000800
[00:57:36.078] kernel write flash buffer addr: 000CF800 len: 00000800
[00:57:36.187] kernel validate flash addr: 000CF000 len: 00001000 crc32: 45bc9dac
[00:57:36.218] kernel write flash buffer addr: 000D0000 len: 00000800
[00:57:36.343] kernel write flash buffer addr: 000D0800 len: 00000800
[00:57:36.468] kernel validate flash addr: 000D0000 len: 00001000 crc32: 86905d0b
[00:57:36.515] kernel write flash buffer addr: 000D1000 len: 00000800
[00:57:36.640] kernel write flash buffer addr: 000D1800 len: 00000800
[00:57:36.765] kernel validate flash addr: 000D1000 len: 00001000 crc32: c4d8f0d3
[00:57:36.796] kernel write flash buffer addr: 000D2000 len: 00000800
[00:57:36.906] kernel write flash buffer addr: 000D2800 len: 00000800
[00:57:37.031] kernel validate flash addr: 000D2000 len: 00001000 crc32: 62d219f7
[00:57:37.078] kernel write flash buffer addr: 000DB000 len: 00000800
[00:57:37.203] kernel write flash buffer addr: 000DB800 len: 00000800
[00:57:37.328] kernel validate flash addr: 000DB000 len: 00001000 crc32: 7328791e
[00:57:37.375] kernel write flash buffer addr: 000DC000 len: 00000800
[00:57:37.500] kernel write flash buffer addr: 000DC800 len: 00000800
[00:57:37.625] kernel validate flash addr: 000DC000 len: 00001000 crc32: 0ad5ba22
[00:57:37.671] kernel write flash buffer addr: 000DF000 len: 00000800
[00:57:37.812] kernel write flash buffer addr: 000DF800 len: 00000800
[00:57:37.953] kernel validate flash addr: 000DF000 len: 00001000 crc32: ff43226b
[00:57:38.000] kernel flash disable
[00:57:38.031] verifying result...
[00:57:38.031] comparing ECU flash memory pages to image file
[00:57:38.031] seg  start    len        ecu CRC32    img CRC32  same?
[00:57:38.062] FB01 00000000 00001000   0B9158D5     0B9158D5     YES
[00:57:38.109] FB02 00001000 00001000   EA035F4B     EA035F4B     YES
[00:57:38.156] FB03 00002000 00001000   45CE543F     45CE543F     YES
[00:57:38.203] FB04 00003000 00001000   B585C9DF     B585C9DF     YES
[00:57:38.234] FB05 00004000 00001000   B5A95EAB     B5A95EAB     YES
[00:57:38.281] FB06 00005000 00001000   3A1F0459     3A1F0459     YES
[00:57:38.312] FB07 00006000 00001000   C90AB7B9     C90AB7B9     YES
[00:57:38.359] FB08 00007000 00001000   89F5D89F     89F5D89F     YES
[00:57:38.640] FB09 00008000 00018000   15019EFD     15019EFD     YES
[00:57:39.000] FB10 00020000 00020000   920B1059     920B1059     YES
[00:57:39.343] FB11 00040000 00020000   596AD159     596AD159     YES
[00:57:39.687] FB12 00060000 00020000   D61A2B44     D61A2B44     YES
[00:57:40.062] FB13 00080000 00020000   FAFC2FB3     FAFC2FB3     YES
[00:57:40.421] FB14 000A0000 00020000   AE59A32B     AE59A32B     YES
[00:57:40.781] FB15 000C0000 00020000   8B062089     36439BE1      NO
[00:57:41.140] FB16 000E0000 00020000   4E07494B     E12BF0E9      NO
[00:57:41.187] interface close
[00:57:41.281] interface close
[00:58:10.328] J2534 API Version: 04.04
[00:58:10.328] J2534 DLL Version: 0.50.2150 Oct  9 2008 12:45:03
[00:58:10.328] Device Firmware Version: 1.01.2145
[00:58:16.296] kernel get version
[00:58:16.390] J2534 error [ERR_TIMEOUT].
[00:58:16.421] SSM2 init
[00:58:16.515] J2534 error [ERR_TIMEOUT].
[00:58:16.546] interface close
[00:58:16.656] interface close
[00:58:51.593] J2534 API Version: 04.04
[00:58:51.593] J2534 DLL Version: 0.50.2150 Oct  9 2008 12:45:03
[00:58:51.593] Device Firmware Version: 1.01.2145
[00:58:55.906] kernel get version
[00:58:56.296] SSM2 init
[00:58:56.375] SSM2 ECU ID is 4B 52 50 41 07
[00:58:56.406] Requesting Seed...
[00:58:56.484] Sending Key...
[00:58:59.343] kernel get version
[00:58:59.390] kernel version is : OpenECU Subaru SH7058 OCP CAN Kernel V1.06
[00:58:59.390] reading kernel comm buffer size
[00:58:59.437] comm buffer size set to 2048
[00:58:59.437] reading kernel flash buffer size
[00:58:59.484] flash buffer size set to 4096
[00:58:59.484] Flashing image to ECU memory...
[00:58:59.890] comparing ECU flash memory pages to image file
[00:58:59.890] seg  start    len        ecu CRC32    img CRC32  same?
[00:58:59.937] FB01 00000000 00001000   0B9158D5     0B9158D5     YES
[00:58:59.968] FB02 00001000 00001000   EA035F4B     EA035F4B     YES
[00:59:00.015] FB03 00002000 00001000   45CE543F     45CE543F     YES
[00:59:00.062] FB04 00003000 00001000   B585C9DF     B585C9DF     YES
[00:59:00.109] FB05 00004000 00001000   B5A95EAB     B5A95EAB     YES
[00:59:00.156] FB06 00005000 00001000   3A1F0459     3A1F0459     YES
[00:59:00.187] FB07 00006000 00001000   C90AB7B9     C90AB7B9     YES
[00:59:00.218] FB08 00007000 00001000   89F5D89F     89F5D89F     YES
[00:59:00.515] FB09 00008000 00018000   15019EFD     15019EFD     YES
[00:59:00.875] FB10 00020000 00020000   920B1059     920B1059     YES
[00:59:01.250] FB11 00040000 00020000   596AD159     596AD159     YES
[00:59:01.609] FB12 00060000 00020000   D61A2B44     D61A2B44     YES
[00:59:01.984] FB13 00080000 00020000   FAFC2FB3     FAFC2FB3     YES
[00:59:02.343] FB14 000A0000 00020000   AE59A32B     AE59A32B     YES
[00:59:02.703] FB15 000C0000 00020000   8B062089     36439BE1      NO
[00:59:03.062] FB16 000E0000 00020000   4E07494B     E12BF0E9      NO
[00:59:03.062] kernel flash enable
[00:59:03.109] kernel blank flash page: addr: 000E0000
[00:59:03.828] erased in 1 pulse(s)
[00:59:03.828] kernel write flash buffer addr: 000FF000 len: 00000800
[00:59:03.968] kernel write flash buffer addr: 000FF800 len: 00000800
[00:59:04.093] kernel commit flash addr: 000FF000 len: 00001000 crc32 0537942f
[00:59:04.156] written in 1 pulse(s)
[00:59:04.156] kernel blank flash page: addr: 000C0000
[00:59:05.828] erased in 1 pulse(s)
[00:59:05.828] kernel write flash buffer addr: 000C0000 len: 00000800
[00:59:05.953] kernel write flash buffer addr: 000C0800 len: 00000800
[00:59:06.078] kernel commit flash addr: 000C0000 len: 00001000 crc32 5d882503
[00:59:06.140] written in 1 pulse(s)
[00:59:06.140] kernel write flash buffer addr: 000C1000 len: 00000800
[00:59:06.265] kernel write flash buffer addr: 000C1800 len: 00000800
[00:59:06.390] kernel commit flash addr: 000C1000 len: 00001000 crc32 aefb11f8
[00:59:06.453] written in 1 pulse(s)
[00:59:06.453] kernel write flash buffer addr: 000C2000 len: 00000800
[00:59:06.562] kernel write flash buffer addr: 000C2800 len: 00000800
[00:59:06.687] kernel commit flash addr: 000C2000 len: 00001000 crc32 64de5462
[00:59:06.765] written in 1 pulse(s)
[00:59:06.765] kernel write flash buffer addr: 000C3000 len: 00000800
[00:59:06.890] kernel write flash buffer addr: 000C3800 len: 00000800
[00:59:07.015] kernel commit flash addr: 000C3000 len: 00001000 crc32 c552b6ff
[00:59:07.078] written in 1 pulse(s)
[00:59:07.078] kernel write flash buffer addr: 000C4000 len: 00000800
[00:59:07.203] kernel write flash buffer addr: 000C4800 len: 00000800
[00:59:07.328] kernel commit flash addr: 000C4000 len: 00001000 crc32 1f7d9e81
[00:59:07.390] written in 1 pulse(s)
[00:59:07.390] kernel write flash buffer addr: 000C5000 len: 00000800
[00:59:07.515] kernel write flash buffer addr: 000C5800 len: 00000800
[00:59:07.640] kernel commit flash addr: 000C5000 len: 00001000 crc32 22115aab
[00:59:07.703] written in 1 pulse(s)
[00:59:07.703] kernel write flash buffer addr: 000C6000 len: 00000800
[00:59:07.828] kernel write flash buffer addr: 000C6800 len: 00000800
[00:59:07.953] kernel commit flash addr: 000C6000 len: 00001000 crc32 c24bba73
[00:59:08.015] written in 1 pulse(s)
[00:59:08.015] kernel write flash buffer addr: 000C7000 len: 00000800
[00:59:08.125] kernel write flash buffer addr: 000C7800 len: 00000800
[00:59:08.250] kernel commit flash addr: 000C7000 len: 00001000 crc32 d8dcea8c
[00:59:08.328] written in 1 pulse(s)
[00:59:08.328] kernel write flash buffer addr: 000C8000 len: 00000800
[00:59:08.453] kernel write flash buffer addr: 000C8800 len: 00000800
[00:59:08.578] kernel commit flash addr: 000C8000 len: 00001000 crc32 58afc290
[00:59:08.640] written in 1 pulse(s)
[00:59:08.640] kernel write flash buffer addr: 000C9000 len: 00000800
[00:59:08.765] kernel write flash buffer addr: 000C9800 len: 00000800
[00:59:08.890] kernel commit flash addr: 000C9000 len: 00001000 crc32 5d18c549
[00:59:08.953] written in 1 pulse(s)
[00:59:08.953] kernel write flash buffer addr: 000CA000 len: 00000800
[00:59:09.078] kernel write flash buffer addr: 000CA800 len: 00000800
[00:59:09.203] kernel commit flash addr: 000CA000 len: 00001000 crc32 cc25cd8f
[00:59:09.265] written in 1 pulse(s)
[00:59:09.265] kernel write flash buffer addr: 000CB000 len: 00000800
[00:59:09.390] kernel write flash buffer addr: 000CB800 len: 00000800
[00:59:09.515] kernel commit flash addr: 000CB000 len: 00001000 crc32 0ed5a482
[00:59:09.578] written in 1 pulse(s)
[00:59:09.578] kernel write flash buffer addr: 000CC000 len: 00000800
[00:59:09.703] kernel write flash buffer addr: 000CC800 len: 00000800
[00:59:09.828] kernel commit flash addr: 000CC000 len: 00001000 crc32 9f48d077
[00:59:09.890] written in 1 pulse(s)
[00:59:09.890] kernel write flash buffer addr: 000CD000 len: 00000800
[00:59:10.015] kernel write flash buffer addr: 000CD800 len: 00000800
[00:59:10.140] kernel commit flash addr: 000CD000 len: 00001000 crc32 097e1777
[00:59:10.203] written in 1 pulse(s)
[00:59:10.203] kernel write flash buffer addr: 000CE000 len: 00000800
[00:59:10.328] kernel write flash buffer addr: 000CE800 len: 00000800
[00:59:10.453] kernel commit flash addr: 000CE000 len: 00001000 crc32 fd6d9774
[00:59:10.515] written in 1 pulse(s)
[00:59:10.515] kernel write flash buffer addr: 000CF000 len: 00000800
[00:59:10.640] kernel write flash buffer addr: 000CF800 len: 00000800
[00:59:10.765] kernel commit flash addr: 000CF000 len: 00001000 crc32 45bc9dac
[00:59:10.828] written in 1 pulse(s)
[00:59:10.828] kernel write flash buffer addr: 000D0000 len: 00000800
[00:59:10.953] kernel write flash buffer addr: 000D0800 len: 00000800
[00:59:11.078] kernel commit flash addr: 000D0000 len: 00001000 crc32 86905d0b
[00:59:11.140] written in 1 pulse(s)
[00:59:11.140] kernel write flash buffer addr: 000D1000 len: 00000800
[00:59:11.265] kernel write flash buffer addr: 000D1800 len: 00000800
[00:59:11.390] kernel commit flash addr: 000D1000 len: 00001000 crc32 c4d8f0d3
[00:59:11.453] written in 1 pulse(s)
[00:59:11.453] kernel write flash buffer addr: 000D2000 len: 00000800
[00:59:11.578] kernel write flash buffer addr: 000D2800 len: 00000800
[00:59:11.703] kernel commit flash addr: 000D2000 len: 00001000 crc32 62d219f7
[00:59:11.765] written in 1 pulse(s)
[00:59:11.765] kernel write flash buffer addr: 000DB000 len: 00000800
[00:59:11.906] kernel write flash buffer addr: 000DB800 len: 00000800
[00:59:12.031] kernel commit flash addr: 000DB000 len: 00001000 crc32 7328791e
[00:59:12.093] written in 1 pulse(s)
[00:59:12.093] kernel write flash buffer addr: 000DC000 len: 00000800
[00:59:12.218] kernel write flash buffer addr: 000DC800 len: 00000800
[00:59:12.343] kernel commit flash addr: 000DC000 len: 00001000 crc32 0ad5ba22
[00:59:12.406] written in 1 pulse(s)
[00:59:12.406] kernel write flash buffer addr: 000DF000 len: 00000800
[00:59:12.546] kernel write flash buffer addr: 000DF800 len: 00000800
[00:59:12.671] kernel commit flash addr: 000DF000 len: 00001000 crc32 ff43226b
[00:59:12.718] written in 1 pulse(s)
[00:59:12.718] kernel flash disable
[00:59:12.765] verifying result...
[00:59:12.765] comparing ECU flash memory pages to image file
[00:59:12.765] seg  start    len        ecu CRC32    img CRC32  same?
[00:59:12.812] FB01 00000000 00001000   0B9158D5     0B9158D5     YES
[00:59:12.859] FB02 00001000 00001000   EA035F4B     EA035F4B     YES
[00:59:12.906] FB03 00002000 00001000   45CE543F     45CE543F     YES
[00:59:12.953] FB04 00003000 00001000   B585C9DF     B585C9DF     YES
[00:59:12.984] FB05 00004000 00001000   B5A95EAB     B5A95EAB     YES
[00:59:13.031] FB06 00005000 00001000   3A1F0459     3A1F0459     YES
[00:59:13.078] FB07 00006000 00001000   C90AB7B9     C90AB7B9     YES
[00:59:13.125] FB08 00007000 00001000   89F5D89F     89F5D89F     YES
[00:59:13.406] FB09 00008000 00018000   15019EFD     15019EFD     YES
[00:59:13.781] FB10 00020000 00020000   920B1059     920B1059     YES
[00:59:14.140] FB11 00040000 00020000   596AD159     596AD159     YES
[00:59:14.515] FB12 00060000 00020000   D61A2B44     D61A2B44     YES
[00:59:14.890] FB13 00080000 00020000   FAFC2FB3     FAFC2FB3     YES
[00:59:15.250] FB14 000A0000 00020000   AE59A32B     AE59A32B     YES
[00:59:15.609] FB15 000C0000 00020000   36439BE1     36439BE1     YES
[00:59:15.984] FB16 000E0000 00020000   E12BF0E9     E12BF0E9     YES
[00:59:15.984] flash correct! exiting.
[00:59:16.031] interface close
[00:59:16.125] interface close
hmanxx
