Hello,
I'm try to read the Subaru Outback 2.5 2005 / 3.0 2006 and can't find any working module.
I connect the OBD2 plug and try all subau's variants and don't get any ECU response.
Maybe I need to use the small subaru connectors..? Under the Steering wheel only the plastic covers... Does any connectors which should I use or this vechile unsupported by 1.3 interface?..
I know some vechiles not listed, but has the same ECU as supported one's.
Thank you.
