Yamaha motorcycle ECU
Postby Jack_K » Fri Aug 22, 2008 12:54 pm
The ECU in my Yamaha Stratoliner is a Mitsubishi F008T83271. Does anyone know where I can find some information on it? Or the F008T83971?
Thanks,
Jack
Jack_K
Re: Yamaha motorcycle ECU
Postby christian_piasini » Mon Jan 12, 2009 2:04 pm
post some pictures and full details of your motorcycle too.
Best regards
Postby Jack_K » Tue Feb 02, 2010 1:54 pm
The ECU is a Mitsubishi F008T83271 and it has 2 connectors on it. One connector has 2 rows of 17 pins and the other has 2 rows of 9 pins. The microprocessor is a 68HC16 with a 4.0 MHz crystal.
Jack_K
Postby Rhinoman » Fri Feb 19, 2010 4:11 pm
The forum linked below is much more motorcycle based. Psyche is the man you need to speak to, he has written Windows software to communicate with the 68HC16 using a very low cost BDM interface. I have used it myself a couple of times.
http://www.activeboard.com/forum.spark? ... 404959&p=2
Rhinoman
