Found the ignition trim maps for engine temp and air temp today too.
Disassembly helps in finding the scale addresses afterwards as well as links to other maps, but it is systematic searching and testing that finds what all of the maps at all of the addresses do.
The only map that is proving to be elusive is the fuel map vs engine temp. I have ripped this rom apart and cant find it as yet. The ignition vs air temp map has a second map that controls the load at which it becomes active, so at idle and cruising you dont see changes to the trim map. That made it difficult to find. I am starting to think the fuel vs coolant map does something similar. If it's there I will find it.
