Hi
I'm looking for information on the DSM protocol used on my Suzuki Vitara. I'm hoping it may be common to other vehicles. I have an OBD2 connector with a one-wire interface on pin 9. I have captured the data transfer between the immobilizer and the ECU and it looks to be 16KHz 8N1. Data line is at 5V idle. I'm going to make an interface to hook it up to a PC and try and log the datastream.
I get one data exchange when the ignition is turned on, I'm pretty sure that this is the immobilizer, because if I disconnect it the CEL flashes, first byte is 0x99. I also get a second data exchange when the starter is engaged (0x98), maybe airbag? although my model doesn't have any fitted they were fitted to models sold in other countries.
Any clues/ideas gratefully accepted
Cheers
James
