Problem with flashing Evo IX
Postby PibusEVO » Mon Feb 25, 2008 2:59 pm
Hello guys
I have a problem with my EVO IX which was already discussed in the forum, but I couldn't find any actual solution. Does any of you have the solution?
The problem occurs by writing/comparing. By reading no problem:
sending init sequence 1 (0001)
got 0x05 response
sending init sequence 2
got 0x1B response
sending init sequence 3
entering bootloader
sending kernel size (4452)
sending kernel load address (0xFFFF7000)
uploading kernel
verifying kernel checksum response
kernel valid
kernel get version
rkrv: preamble 1 error
reading kernel comm buffer size
reading kernel flash buffer size
interface close
interface close
I'm using ECUFlash 1.34, although I tried also with 1.29 with the same result.
Please help me!
PibusEVO
PibusEVO
Postby radsdau » Wed Feb 27, 2008 3:39 pm
The kernel is uploading correctly, but not running.
This looks like the EVO8 hookup method; my guess is that your XML is wrong (specified as EVO8/7052).
That explains why you can read but not write.
Make sure your XML has these lines:
<submodel>EVO9</submodel>
<flashmethod>mitsukernelocp</flashmethod>
<memmodel>SH7055</memmodel>
Postby PibusEVO » Fri Feb 29, 2008 12:04 am
Hello
it is specified like that except for the flashmethod.
In my xml there is
<flashmethod>mitsukernel</flashmethod>
Can this be the problem?
Reading works flawless
PibusEVO
radsdau wrote:The kernel is uploading correctly, but not running.
PibusEVO
Postby mentalevolution » Fri May 23, 2008 7:45 am
Hey im having the same issue??? Any help?
mentalevolution
Postby h101171 » Sun May 25, 2008 8:14 am
mentalevolution wrote:Hey im having the same issue??? Any help?
I am having the same problem as well. I could download proberly but not read. And what is the most important issue, there is no ID.# . So, I cant figure out the XML-Definition File.
Greets
Marcel
h101171
Postby radsdau » Sun May 25, 2008 3:13 pm
PibusEVO wrote:it is specified like that except for the flashmethod.
In my xml there is
I'm almost 100% sure this is the problem. Must be OCP.
