Frenzy wrote:What's better with the LM2 ?
The new LM-2 model's got some neat features, just a bit expensive if you only need AFR.
OBD-II scan tool built in (like the OT-1 onboard)
Log directly to SD card
Playback log data on screen or with powerful analysis software LogWorks 3.0
High-contrast graphics LCD
Built-in RPM converter (inductive clamp or direct frequency)
4 fully-differential analog inputs
2 configurable analog outputs
Positive lock connectors for all connections
Innovate MTS serial in and out
USB connection
Preliminatry Data Sheet for the LM-2
