I need a definition file: 2001 Dodge Stratus
Postby travman27 » Mon May 05, 2008 3:56 pm
Ok so I was messing with my gf's stratus because she had a cel so I got my tactrix cable and laptop to see if i can connect to it through scan tech. Well when i found the plug under the dash i saw the white plug as well just like my evo to flash?
So I connected to the car, cleared her cel - then said i wonder if i can read your ecu? so I hooked it up and downloaded the rom - but the definition isnt found so I cant look at it.
I know the car is the same as the 3rd gen eclipse because she has had to get a few parts from mitsu for it......Thats why I originally posted a 3rd gen eclipse since they are basically the same car with same motor and different body. Sorry.....didnt think anyone would be willing to help knowing it was a dodge :)
This is all strictly for fun and to mess around - so if anyone can help me figure out what the def. would be I would appreciate it...
Its a 2001 Dodge Stratus, 2.4L - automatic
UPDATE: I got the rom files from this site http://www.club3g.com/forum/showthread. ... hlight=ROM
but non for the eclipse or stratus were recognized when i went to open her rom....
2001 Stratus undefined.hex
(256 KiB) Downloaded 661 times
travman27
Postby Keiran » Fri May 23, 2008 7:40 pm
<table name="fuel map" address="4fa1">
<table name="Load" address="578e" elements="10"/>
<table name="RPM" address="5768" elements="14"/>
</table>
<table name="Timing Map" address="5039">
<table name="X" address="57da" elements="12"/>
<table name="Y" address="57ac" elements="18"/>
</table>
something for you to work with :D
Let me know if you need other stuffs ..
Keiran
Postby travman27 » Sat May 31, 2008 7:43 am
Only problem - I dont have a definition file to open the rom?
I am still looking for a definition file to paste into ecuflash so it will recognize the rom
travman27
Postby radsdau » Sun Jun 01, 2008 3:13 pm
That looks remarkably similar in a lot of ways to an EVO7/8 ROM; I'm assuming it has an SH 7052 processor?
Postby Keiran » Mon Jun 02, 2008 4:38 am
travman27 wrote:Only problem - I dont have a definition file to open the rom?
Here ya go .. you may not have all the required definition .. but it'll work
85850014.xml
(785 Bytes) Downloaded 673 times
Keiran
Postby radsdau » Mon Jun 02, 2008 3:26 pm
What?? ROM ID at F52? Identical info block at 3FFC0?
Did I say similar to EVO7/8? :)
I didn't know Dodge and Mitsubishi were connected...
Postby Keiran » Mon Jun 02, 2008 3:53 pm
radsdau wrote:What?? ROM ID at F52? Identical info block at 3FFC0?
It's actually closer to the base lancer :lol:
Keiran
Postby travman27 » Fri Jun 06, 2008 4:48 pm
It worked - but all i have access to is the immobilizer and init code...
Thanks a ton for the help!!
...now where do i go from here to be able to see fuel and timing maps?
travman27
Postby Keiran » Fri Jun 06, 2008 9:10 pm
travman27 wrote:It worked - but all i have access to is the immobilizer and init code...
It's in there .. just can't remember which one I used .. there's only 1 map unlike the 2 in Evo's
It's a very simple 2002 version Base Lancer map .. no low octane maps
Oh yes.. and make sure you enable developer instead of beginner :lol:
Keiran
Postby travman27 » Mon Jun 09, 2008 8:46 am
I have no fuel or timing maps - nothing is in my xml file except the rom data?
Yeah my ecuflash is in developer mode because I do all my own stuff on the evo and have every patch/rom mod that is out.
This is all I have:
<rom>
<romid>
<xmlid>85850014</xmlid>
<internalidhex>85850014</internalidhex>
<caseid>SM8585</caseid>
<ecuid>XM8585</ecuid>
<make>Chrysler</make>
<market>USDM</market>
<model>Stratus</model>
<year>2001</year>
<flashmethod>mitsukernel</flashmethod>
<memmodel>SH7052</memmodel>
</romid>
<include>evo7base</include>
</rom>
travman27
Postby travman27 » Mon Jun 09, 2008 9:18 am
On a new note.......
I copied some things into the xml file you gave me from another stratus xml file (85120032) and I did get some info out of it but the fuel and timing maps plus some other stuff are all scrambled so the addresses are probably not correct but its a step closer possibly?
If you get a chance plug the xml file in and look at the rom and see what you think......I attached the xml file with all the info i pasted into it.
Thanks!
(256 KiB) Downloaded 646 times
85850014.xml
(5.06 KiB) Downloaded 654 times
travman27
Postby Keiran » Mon Jun 09, 2008 1:36 pm
Keiran wrote:<table name="fuel map" address="4fa1">
</table>
</table>
Add this into the your file .. sorry .. didn't check the xml I sent .. but it should have included this inside since this was where I got this
Keiran
Postby Loud and Low Custom » Wed Aug 27, 2008 9:36 am
</table>
</table>
Where are you supposed to input this?
Loud and Low Custom
Postby Loud and Low Custom » Sat Sep 13, 2008 11:43 pm
travman27 wrote:On a new note.......
Thanks!
How do you download this into a file that is usable? All I got was a window with the contents.
Loud and Low Custom
