Can i upload a E7 Rom in an E8 ECU?
Postby Amukinado » Sun Feb 24, 2008 10:12 am
Hi,
I have bought an ECU from a E8 260 to fit in my EDM E6 RS2.
Can i upload a E7 rom to the E8 ECU or not?
Will it be safe to run my E6 with a Ralliart Rom from E7 or E8?
Thanks,
Pedro
Amukinado
Postby radsdau » Sun Feb 24, 2008 3:32 pm
FIRST: make sure you read and back up your original ROM file!!
If you're running your car on a ROM not made for it, it's likely to be BAD. You will almost certainly have to make a custom tune.
You can put he E7 into E8 ECU, but it will probably not run. I think the immobilizer works differently. Either way, it's no big deal; you can always put your original ROM back in.
I am also pretty sure that the ECU pin functions are not the same (there will be other people who can confirm this).
Postby Amukinado » Tue Feb 26, 2008 12:52 am
But can i read the E6 rom from my OE ECU with ECU Flash?
And can i write my E6 rom to the E8 ECU?
Thanks,
Pedro
Amukinado
Postby todd-w » Tue Feb 26, 2008 1:39 pm
im running my evo4 on a 7 ecu with some pin changes and a patch or two , some pinouts on 7/8 ecu are different to evo6 ,, 7ecu is probably the better choice , have a look in here ,
http://forums.openecu.org/viewtopic.php ... highlight=
todd-w
Postby radsdau » Wed Feb 27, 2008 3:33 pm
Amukinado wrote:But can i read the E6 rom from my OE ECU with ECU Flash?
Yeah you should be able to read it, but:
Amukinado wrote:And can i write my E6 rom to the E8 ECU?
No- the micros are different. E7 and E8 ECUs are the same, but there are some differences in how the code works, immobilizer being one of them I think.
What I meant was, read the ROM in the E8 ECU first.
I'd suspect immobilizer to be your biggest hassle, but there are people here who have worked it out successfully, they'll tell you how.
Postby todd-w » Thu Feb 28, 2008 12:57 am
immobiliser aint a problem
todd-w
Postby radsdau » Thu Feb 28, 2008 3:33 pm
todd-w wrote:immobiliser aint a problem
Thanks. Happy to be proved wrong!
Postby burgers » Thu Mar 06, 2008 3:04 pm
radsdau wrote:FIRST: make sure you read and back up your original ROM file!!
Actualy there are several guys in the UK running Evo 7 Ralliart ROMs on Evo 7 ECUs in their early Evos. You do have to mod the radiator fan wires though. There are some threads on here on how to do it. By the way I'm working In Lisbon soon.
MB
burgers
Postby Amukinado » Fri Mar 07, 2008 4:53 am
Nibe to hear it burguers...
I'm from Oporto, which is 300 Km from Lisbon but maybe we can figure out a coffee...
Where you will be working?
Amukinado
Postby franck » Fri Mar 14, 2008 8:23 am
i sir
I have one evo8 eudm french
my question is that I can put the rom of the FQ300 ID93660005 to replace my rom ID96530006?
thank you
franck
Postby franck » Fri Mar 14, 2008 8:52 am
i m test today
is not work :(
franck
Postby todd-w » Fri Mar 14, 2008 11:58 am
franck wrote:i m test today
is not work :(
do you mean it wont start ?????
todd-w
Postby franck » Fri Mar 14, 2008 12:26 pm
is not work :(
yes
is not start engine :(
franck
Postby todd-w » Sun Mar 16, 2008 9:17 am
try this one
Evo 8 todd fq320.hex
(256 KiB) Downloaded 656 times
todd-w
Postby franck » Sun Mar 16, 2008 11:53 am
ok
thank :wink:
franck
