Ok, so I've disabled some ECU trouble codes using RomRaider. The question I have is...
Once I've driven around a bunch (how far?? more than 50 miles?) will the ECU eventually go into a state of ready to read for emissions?
Thanks!
No, it's not yet available for 32-bit ECUs. You failed to mention what model Subaru you are talking about.1FastSTi wrote:Force readiness seems to be in the 16 bit ECU defs. (http://www.romraider.com/forum/about360.html) I'm not at a PC with a rom available. Is that feature available in 32 bit versions?
