M32R
Links to development tools which have been useful to this project
M32R
Postby Marmes » Wed Jan 02, 2008 2:29 pm
Hello!
Does anyone have some tools for M32R processors?
Thanks!
Marmes
Postby wmcdonal » Tue Jan 22, 2008 7:52 pm
Yes, what exactly are you looking for ?
wmcdonal
Postby salex » Wed Jan 23, 2008 2:44 pm
Renesas has a tool for flashing the evaluation boards containing it.
It is called M3S-UFLA32R, but it is only able to flash - not read.
Any other ideas? :)
salex
Postby Marmes » Wed Jan 23, 2008 2:48 pm
After reading some datasheets, It seems that everything to be able to read the flash is there explained,doesn't seem to be very hard.
It even says that the only protection this processor has is a pin pulled to to a state Low to prevent the ecu to be read or written, I know there are other kind of protections ,the ones used by some companies here to protect their work where they set an ID.
What we need is a simple iso 9141 interface with some dc to dc converter to pull the voltage up to disable the protection.
But this is me guessing.
Cheers!
Marmes
Postby salex » Sun Jan 27, 2008 9:16 am
The manuals seem very interesting. I wonder what sort of interface we might be able to build following the instructions!
salex
Postby Marmes » Wed Jan 30, 2008 9:38 am
I think what it's needed is to put the FP in High state to put processor in boot mode and read.
This is me guessing again :S
Marmes
Postby salex » Wed Jan 30, 2008 1:02 pm
Marmes wrote:I think what it's needed is to put the FP in High state to put processor in boot mode and read.
That is the main idea, but it will take more than the instructions in the manual to be able to read. Boot mode supports writing in this one :-)
salex
Postby Marmes » Wed Jan 30, 2008 1:52 pm
What can we do to read it?, can we use the tactrix cable for mistubishi?
Marmes
Is the MR32 this ones?
Postby christian_piasini » Sun Feb 03, 2008 2:05 am
Hello, it is the MR32 the mcu you see in the picture below?
Regards
Postby Marmes » Sun Feb 03, 2008 5:53 am
yes it is.
you think its not?
Then explain yourself :)
Best Regards!
Marmes
I think is...
Postby christian_piasini » Fri Feb 08, 2008 9:37 am
Yes it is, I joke ....
some times as well has to joke a little bit.....
Regards
Postby Marmes » Fri Feb 08, 2008 11:08 am
that one has a jtag port, i think it is...
Marmes
I don't need the Jtag port
Postby christian_piasini » Fri Feb 08, 2008 2:08 pm
With this ecu we don't need to read it trough the JTAG....
we do it trough the ecu plug, without open it...
Regards
Return to Development Tools
