R. Mutt wrote:BarryC. I noticed you said the immobilizer code for the evo 8 rom was removed. Inspecting the rom I see the immobilizer code set to BD0D.
Could you explain this setting? Reason I ask is I hear that playing with the immobilizer code can be dangerous and have never altered it before. Most people (on evolutionm.net) say you should save a copy of the original rom because if u lose your immobilizer code you're screwed. I usually see a 4 digit number in most ROMs I pull.
I'm looking to do an Evo 7 ECU conversion on an Evo 6. I'll most likely use a JDM 7 GSR stock rom but I'm asking just in case.
