Can someone take a look at the logs I pulled last night, And let me know if there is anything I should worry about. I just flashed stage 2 with an xpt base map for now. The iam numbers are wacked because we used the value for an 02 because we weren't sure of which one to use. Also I'm getting a little backfire from full throttle to closed throttle pulls.
Thanks in advance.
