Ecutek lock out..
Ecutek lock out..
Postby 06STi » Fri Jan 04, 2008 12:08 pm
Anyone help me free up my ecu so I can tune it.
06STi
Postby NeverLies » Fri Jan 04, 2008 1:10 pm
Have you tried to flash it stock this way : http://www.openecu.org/index.php?title=SHBootMode ?
Postby vaccine » Fri Jan 04, 2008 2:39 pm
whomever put the ecutek on should be able to return it too stock!
vaccine
Postby Dweeb » Sat Jan 05, 2008 7:07 pm
where are you located, i may be able to help you out ...
Dweeb
Postby lester » Sun Jan 06, 2008 12:45 pm
i would like to get around my ecutek lockout too. i'm located in an area where the closest reputable ecutek tuner is about 9hrs away.
lester
Postby hmanxx » Mon Jan 07, 2008 8:34 am
NeverLies wrote:Have you tried to flash it stock this way : http://www.openecu.org/index.php?title=SHBootMode ?
Can this boot mode writing really be able to overwrite whatever Ecut*k has locked out ?
How about 16bits processor..is there similar way to force ecu to boot mode ?
I am living at Singapore, not as fortunate on customer right to boycott ecut*k.
ecutek tuners there basically quoting no way to revert ..the problem is some users bought the car used with ecut*k bad DNA on it..and users just leave with no choice ,cant go back to Dealer and go for ECU reflash solution.
hmanxx
Postby NeverLies » Mon Jan 07, 2008 11:08 am
Not tested yet. I did ask Colby but no answer :(
Maybe someone has already tested this method ? I don't know why it may not work, as it works in boot mode. No read operation can be done, but write operation can be.
Regarding 16bits, there's such hardwware to do it, but it costs much more !! P&E sells one, I know Colby use it already but also don't know if someone has used it to lockout an ecut**k ecu ??
Postby Dweeb » Mon Jan 07, 2008 3:58 pm
there is a way to read a ecutek locked ECU via the OBDII port.... done 16 bit, but haven't tried 32bit yet
Dweeb
Postby steve_s13 » Tue Jan 08, 2008 5:23 pm
how do you do it then? whats the step by step procedure??
steve_s13
Postby Freon » Tue Jan 08, 2008 5:54 pm
shbootmode should be able to overwrite almost anything short of a hardware failure.
Postby Hyper » Sun Jan 13, 2008 2:30 pm
Dweeb wrote:there is a way to read a ecutek locked ECU via the OBDII port.... done 16 bit, but haven't tried 32bit yet
I haven't tried 32bit too, but I am pretty sure it works ;)
Hyper
Postby hmanxx » Thu Jan 17, 2008 11:11 pm
Totally not keen on ecutek map..only keen on overwriting it to restore to standard comm protocol.
Can the software overwrite the ecutek maps and restore back to stock map or same year car code to the ecu ?
hmanxx
Postby salex » Fri Jan 18, 2008 7:43 am
Sure, you just have to find your ecu's original software version.
salex
Postby 06STi » Mon Jan 21, 2008 10:53 pm
I can use enginuity logger to log my ecutek
I was to set my ecu free. I feel like its stuck in the matrix. my local tuner sucks. I'm almost thinking about talking to a lawyer over this lock out b.s.
I would think its illegal for ecutek to do that. I was not even told on sale that I'd be locked out.
I'll just list my email address incase someone wants to help.
michael@boosted-subie.com
06STi
Postby LOK11 » Tue Jan 22, 2008 6:30 pm
Hi all,
We may be able to assist you but you would have to send your ECU to Australia and we would only re-instate original programs. We would not supply a copy of the program that was in your ECU if it was locked by another tuners’ method. We should be able to do any EVOVII onward and all Subaru 2001 onward as well. We had not envisaged supplying this service, but it seems there are a few people who require it.
Let us know if this is something that people are interested in please.
Regards
Lachlan Riddel
Technical Director
ChipTorque
LOK11
Return to OpenECU Software
