problem with flashing and 03 JDM EVO 8 GSR
see attached files (original and amended for reading using a definition file kindly hosted on this forum)
no today i did a flash and all was ok. then went to do another flash with a revised map and now no joy, the car dont start,
I also tried to flash back my original and I could flash every other file and read from the ecu fine (tested 3 laptops and a macbook so I know i havebt got a PC or Mac issue) and i figd I couldt have done any permanent damage as the cable is reading off the maps flashed, its just they wont start the car
Im new to all this. I mainly tune power fc ecu, and sucessfully too i might add. Just wanted to give this ago and be more consistent with light tuning. ive never had these flash probs before. May be i need fresh eyes on the map.
can someone tell me if the maps are drastically diff? I noticed a MISC section on the map which none of the other spec'd EVO 8 's have. Is this normal. Could this be why the car no longer fires up.
Have i fried the ECU, please help. I need to get this car started and this OPEN ECU stuff is putting me off now and I dont want it to as I know once I get going id like to think I could achieve some good results.
I will post my original map....
and converted one using the definitions provided....
Thanks in advance. please make comment , positive or negative. I just want to knwo where i stand. if i have to go and buy a power fc then so be it, but I dont want to if I can tune with good results on the stock ECU.
also whats the most boost my turbo can handle without compressor surge.
