May I have your help, please? WRX TD05 evo3 16G
Postby silverscooby » Sun Nov 11, 2007 12:51 am
I am still very new to the tuning scene. However, I have modified my ROM lately. Would anyone be kind enough to look at my logs and my ROM to see if it is safe for use?
Any comments about my rom and logs are welcome.
EDM WRX 05 2.0 M/T (same hardwares as USDM)
Mod lists
FP TD05H EVO3 16G
STi Intercooler + deflector
STi pink injectors
Walbro 255L fuel pump
GM 3-way boost solenoid
Catless UpPipe
65mm Catless Downpipe
75mm Axleback
Throttle body coolant hose removal
93 gas every time
rev9.hex
(160 KiB) Downloaded 659 times
rev9_20071109_2238.csv
(5.45 KiB) Downloaded 658 times
rev9_20071109_2239.csv
(3.79 KiB) Downloaded 666 times
silverscooby
Postby silverscooby » Sun Nov 11, 2007 9:28 pm
In case you are not logged in, you cant view the attachments.
To download the files, please wait 40 seconds then hit "Click here for download"
http://www.uploading.com/files/ZIX3IB6O/rev9.hex.html (rom)
http://www.uploading.com/files/RAD2PJWN ... 9.csv.html
http://www.uploading.com/en/files/D21FL ... 8.csv.html
I would be grateful if you could let me know if they are safe to run on my car.
silverscooby
Postby 06rexwagon » Tue Nov 13, 2007 12:24 pm
Other than your a/f targets looking too lean for 93 I'd say it looks healthy. Are you tuning with a wideband? The car is accepting plenty of timing and your boost curve looks pretty good.
06rexwagon
Postby silverscooby » Tue Nov 13, 2007 8:48 pm
Nice to meet you 06rexwagon and thank you for looking at my logs and rom.
The problem is that I am not tuning with a wideband. The AFR figures are in fact taken using the stock Front o2 sensor relocated to the DP after the turbo. I am running a full decat system. Would that still be too lean for 93 gas?
Please let me know what kind of target AFR are suitable for my mods and car?
Many thanks
silverscooby
