Unable to read the rom 2002-03 WRX
Postby bbzor » Thu Jan 11, 2007 3:19 pm
Hey all,
I am fairly well familiar with the process, i have tuned a couple of WRX, this one is giving me a headache. I have tried everything at this point to download the stock ROM. This is a 2002 WRX, early model. I have been plugging and unplugging jumpers and connectors for the past 3 hours. Nothing works. This is an error message I'm getting.
[04:26:00.590] denso02_bootloader_cmd_start
[04:26:01.791] denso02_bootloader_cmd_start
[04:26:02.993] denso02_bootloader_cmd_start
[04:26:04.195] denso02_bootloader_cmd_start
[04:26:05.397] denso02_bootloader_cmd_start
[04:26:05.797] kernel get version
The strange thing is that I have to use the 04-05 white jumper block and not 02-03, this car does not have the same white plug as a regular 02-03. Not a driver issue - I just flashed an 05, no problem.
This car is driving me nuts, looking for some advice.
Thank you
bbzor
Postby bbzor » Thu Jan 11, 2007 3:25 pm
Okay got it to work. Used ECU EXPLORER to download HEX and using ECU Flash to edit and upload it.
bbzor
Postby cboles » Fri Jan 12, 2007 4:28 pm
that's weird. EcuExplorer shouldn't really be any different in this way...
Same problem
Postby scoobyroo » Wed Oct 17, 2007 6:12 pm
i have the same exact problem with my brothers car its an 03.
I have reflashed several cars (my 06 tr, 07 sti, 05 wrx), but my brothers car just dosent work.
I connect the green diag. plug and the other one, but for some reason the CEL wont come on unless I unplug the tactrix cable from the ODB II port.
i get the same "kernel get verison" error, its driving me nuts trying to figure it out if anyone has any idea i would appreciate any help.
scoobyroo
Postby cboles » Wed Oct 24, 2007 11:49 pm
Give us a call at 206.388.2714 when you have access to the car and we should be able to help you figure out what is going on.
Postby Piligrim » Sun Jan 20, 2008 12:46 pm
Hi, to all the Guru!
And what to do to owners of Russia? Today too has faced this problem.
Car - WRX for America of 2002.
Whether the decision has been found?
I shall be grateful for the answer.
Piligrim
Postby cboles » Sat Jan 26, 2008 1:42 am
Piligrim: can you send a log of the problem to support@tactrix.com? do you have the green connectors on both sides of the vehicle connected and the reflash jumper attached?
colby
Postby Piligrim » Sun Jan 27, 2008 11:21 am
Thanks Colby, for the answer.
Has found out news unpleasant for, - the adapter "has simply died".
Silently so, easy... Has taken and has died. :( At once I shall tell, it was not tactrix
I have applied a spare variant and... Ооо all has been read through! =))
I a beginner, probably there will be still questions.
Thanks for answers! ;o)
Piligrim
