blackwrx wrote:im running a modified sti fuel map on my wrx and the power curve is alot smoother very impressed. you are only able to change the parameters on the wrx fuel map so much. overall the new map is pretty nice
blackwrx wrote:I'll just tell you the short blocks are the same. the only difference in the motors are the cams, valve train, tuning and some other small differences. an air fuel ratio is an air fuel ratio. thats it the end I'm not leaning it out to the point of knock so dont be so condescending
