Support for Legacy / B4 Twin Turbo 2001 - 2003
Postby Zepp » Thu Aug 11, 2005 4:25 am
Hi, Its great to see all these people getting together for a common goal!
I'm interested to know how many members (if any) have been able to interface to the Legacy / B4 Twin Turbo 2001-2003 (or Liberty, as its called in Australia).
Im particularly interested in the hardware (cable type) that I will need and if it would be basically the same as interfacing with a WRX of the same year. Im pretty sure it an OBD-II style port sitting under my steering wheel.
I'm hoping that any feedback or help to get me started would lead me to be an active contributor to this project.
Zepp
Zepp
Postby Zepp » Thu Aug 11, 2005 4:27 am
I might have posted this question in the wrong area. Sorry about that.
Zepp
Zepp
Postby richip » Thu Aug 11, 2005 1:08 pm
Well, I have an '05 Legacy GT and my OpenPort 1.0 cable shipped today. Chances are we've the same ECU and interface. I'll let you know if I can get mine to work.
richip
Postby bofh » Thu Aug 11, 2005 5:40 pm
It will work in the 05 LGT in the US. I sat in a car belonging to a user on this board, and watched it run the TARi software.
bofh
Postby BoxerFan » Sat Aug 13, 2005 2:31 am
bofh wrote:It will work in the 05 LGT in the US. I sat in a car belonging to a user on this board, and watched it run the TARi software.
May I know which cable was used? 1.0W or 1.0G?
BoxerFan
Postby cboles » Sat Aug 13, 2005 5:59 am
The WRX version will work. Reflashing is possible in the future.
Postby ahains » Fri Sep 23, 2005 7:49 am
Is it also safe/effective to dump the image with ecuflash.exe on a MY05 Legacy GT?
Thanks,
Adrian
ahains
Postby richip » Fri Sep 23, 2005 11:23 am
Let me know if and when you do. I don't have access to a Windows box, but I'd love to get at the ECU code on our Leggies.
richip
Postby Zepp » Tue Dec 06, 2005 10:02 pm
Well, Finally have some spare time again, ordered a openport 1.2, and will let peeps know how I go. Do you think its safe to attempt a rom read at this point ?
Zepp
Zepp
Postby Jeramie » Wed Dec 07, 2005 6:28 am
Can't hurt anything by reading! :wink:
Jeramie
Postby cboles » Wed Dec 07, 2005 10:07 am
ahains wrote:Is it also safe/effective to dump the image with ecuflash.exe on a MY05 Legacy GT?
Thanks,
Adrian
This won't work until I have support for the drive by wire (DBW) ECUs. I hope to get that done by the end of the year.
Postby cboles » Wed Dec 07, 2005 10:09 am
Zepp wrote:Well, Finally have some spare time again, ordered a openport 1.2, and will let peeps know how I go. Do you think its safe to attempt a rom read at this point ?
Zepp
The only side effect of reading out your ECU is that you will erase the learned ECU data in RAM (equivalent to a ECU reset). So it may take a few miles for your car to be running optimally again.
Re: Support for Legacy / B4 Twin Turbo 2001 - 2003
Postby Kosti » Mon Mar 20, 2006 10:40 pm
Zepp wrote:Hi, Its great to see all these people getting together for a common goal!
Zepp
I know this was an old thread, but has there been any further developement?
Just wanting to get as much info as possible.
Cheers
Kosti
Kosti
Postby Zepp » Fri Mar 24, 2006 11:45 pm
I've finally had time to to test the open port 1.2 cable and ecuexplorer on the B4 and Im happy to report that it works!
I only had time to view some real time data so hopefully in the next few days I'll try an ecu rom dump. fingers crossed :D
Zepp
Zepp
Postby mattims » Wed May 24, 2006 4:15 am
I have a 2001 Liberty B4 Twin Turbo (AUS) and i have ecuexplorer working for reading and adjusting trims (ignition idle).
I could read an image with ecuflash and have not yet figured out how to get the maps readable in ecuflash, but im working on it. Any information you have would be greatly appreciated.
b42001standard.hex
The Rom i downloaded (its not configured right)
(160 KiB) Downloaded 1639 times
mattims
