ecuflash unable to load kernel.
Postby 03scoobysnack » Fri Aug 03, 2007 2:16 pm
I have 1.3 tactix, 1.3 ecuflash and the 3.0.25 ecuexplorer.
ok i was able to read my map only once with ecuxplorer. After that time i got a low voltage message and now i only get this:
ecuFlash [11/07/07 @ 19:07:20]
1452 byte kernel read.
196608 byte image read.
ecu image loaded.
denso02_bootloader_cmd_start
kernel flash disable
rkrv: preamble 1 no response
Ecu flash has never workd it always says unable to connect to vehicle interface and i am able to go into diagnostic with ecuexplorer and my vehicle shows up as 03 wrx usdm.
I read on another post that someone was getting the same message and the dealer said that the ecu needed to be replaced because the map is stuck in some mode that prevents the map from communicating.
I dont know what to do so any help is greatly appreciated.
I am now going to reinstall drivers, software for the 30th time and give it a try.
03scoobysnack
