TYPE UK STI PRODRIVE READ AND WRITE ERROR
Postby japerformance » Wed Jul 25, 2007 12:08 pm
Hi ya people how is everyone doing?
i have tried to read a UK type prodrive car 2003 newage ecu and get a read error, from what i understand it has been flashed with the ecutek and wont be readable till the ecutek is removed is that correct.
Is there any other way round this.
Regards
Simon
japerformance
Re: TYPE UK STI PRODRIVE READ AND WRITE ERROR
Postby Jon [in CT] » Wed Jul 25, 2007 5:19 pm
japerformance wrote:... from what i understand it has been flashed with the ecutek and wont be readable till the ecutek is removed is that correct.
It might have been reflashed with EcuTeK (not sure exactly when that software first became available) but it is certainly readable. Maybe you failed to connect the 6-pole Tactrix flash block connector? Where's the EcuFlash log?
Postby japerformance » Fri Jul 27, 2007 9:35 am
oh sugar forgot to copy it before i closed the screen, will post it up in a couple of weeks when i get back home but cmd-081 or somethign similar rings a bell , i have the obd-II connector connected and the 4 pin white block connector fited and the two green plugs under tha dash connected and wouldnt read. on just having the two green ones connected get a kernel error.
thanks again for you advise and help.
cheers
japerformance
