DW 850cc Injector Scaling?
Postby thejean » Wed May 09, 2007 7:39 am
Anyone know what the injector scaling is for the Deutchwerks 850 cc/min injectors?
Thanks, JC
thejean
Postby WerdJack » Fri May 25, 2007 7:57 am
bump.............
WerdJack
how about latency too....
WerdJack
Postby WerdJack » Fri May 25, 2007 7:19 pm
same injectors as above used
6.5     9.0     11.5      14.0    16.5
4.02    2.14   1.42     1.14     0.60
My injector flow was set to 600 cc and I got 14.7-15.1.........
at injector flow 830cc was 19.1........
got info from.....
http://forums.nasioc.com/forums/showthr ... +injectors
still testing........
I have been logging in the UTEC...... what values do you want to examine using enginuity and is there a place to find more info on how to analysis logs....
WerdJack
Postby WerdJack » Sun May 27, 2007 11:33 am
please disregard some of the above info.....I did not have my UTEC Parameters injector scaler values set to the same number...in my case 650/650 versus 650/420..........
Now I have my ecu reflashed to 800 cc injector scaling with the UTEC at 800/800 with the following latency values with much better results..
Code:
Code:
updated 5-28-07
WerdJack
