Evoscan v0.99 doesnt log
Postby sub7 » Wed May 23, 2007 7:24 am
Hi, I got a dodgy problem here. It seems that I could log with Mitsulogger 1.6 Beta 3 (thanks jack!) but I couldn't log with evoscan v0.99.
The evoscan comes up and detect the tactrix cable (using default USB FTDI Mitsu), and as soon as I click Start Datalogger, it get connected but the Reading is not displaying any data. Could it be tactrix driver problem? When I open the .csv file, the TPS are 100 for the entire column, while RPM is 7968.75 (I'm logging only TPS and RPM). I also notice once I start datalog, the car jerk while idle (feel like one of the injector is not working). Doesnt look normal to me.
Final thing, as soon as tactrix cable is connected to the OBDII, the 3 ACD and ABS blink. But when I went above 20kmph, it doesn't blink anymore. Is this normal to evos? I'm driving e7 JDM btw.
Any clue? Much appreciate and thanks!
sub7
Postby sub7 » Wed May 23, 2007 5:21 pm
Found the problem. Evoscan baudrate for some reason set to 1953. Changing USB Cable FTDI to Gen1/Gen2, then change it back to Mitsu reset the Baudrate back to 15625.
Happy flashing!
sub7
