Support for Audi B5 S4 TT
Postby b5s4tt » Thu Apr 12, 2007 1:21 pm
I love what you guys are doing, I wish I had a scooby or a Evo. I have an 2001 Audi S4 Twin Turbo and opensource tuning is something to be desired for this platform. I have a vag cable for this car in the mail and will try and get some logs. I have found that this car uses ME 7.0 Motronic with electronic throttle control.
Some logs from apr program to show you what is going on http://ctny.audiworld.com/mark/s4/ecux/
b5s4tt
Postby b5s4tt » Tue Apr 17, 2007 8:34 pm
I now have the vag cable and can log via vag com. How should i go about dumping from the ecu? I can do a read of all the blocks on the ecu but it takes 45min. Is that data any good?
b5s4tt
Postby cboles » Wed Apr 18, 2007 4:11 pm
b5s4tt wrote:I now have the vag cable and can log via vag com. How should i go about dumping from the ecu? I can do a read of all the blocks on the ecu but it takes 45min. Is that data any good?
I don't know. Do you have a sample file from the reading procedure? Do you know what processor is in the ECU?
Postby b5s4tt » Wed Apr 18, 2007 6:24 pm
some log blocks for boost
http://rapidshare.com/files/26740859/LO ... 0.CSV.html
i found this pdf im looking through to find the rite ecu. i think the edc is for diesel
http://rapidshare.com/files/26740994/sb18.pdf.html
i can do a control module finder from vag-com
b5s4tt
Postby b5s4tt » Wed Apr 18, 2007 7:06 pm
i found this on google, its for a 99 s4. bin
http://rapidshare.com/files/26744559/S4TT-108.bin.html
he says the processor is Siemens C16x based CPU.
http://andywhittaker.com/ECU/BoschMotro ... fault.aspx
b5s4tt
