by tunermt » Wed Apr 11, 2007 9:11 pm
i'm sorry that was a bad description.
i would like to have my subi ignition maps work similar to the evo in the fact that the ecu will look at the knock sencor to pull timing but not to add it. i understand this works well for good power when one doesnt have a dyno to use but if you have a dyno i would rather set up timing as a base map and only have the knock sencor pull timing rather decide if it wants to add more.
mabey i could get the best of both worlds by tuning the car with 0s in the higher load areas of the ignition corection table to get peak torque then add like 1 or 2* of timing to the higher loads so at most the ecu will only add that rather than the 8 or so i see in the stock map i uploaded from a 04.
or mabey i have this completely wrong can the subi ecu pull more timing than what is in the base map or is the base map the loest igniton timing can be?
