EVO VII STOCK ROM 2001 JDM
Postby japerformance » Fri Mar 30, 2007 12:26 pm
As above i have attached the file i downloaded from a JDM EVO VII MANUAL 2001.
I cannot write it to the ecu and also enginuity wont open it either
i have downloaded it and took definition file 98640014
can someone please point me in the direction to solve the problem please.
have attached both files
98640014.xml
(4.93 KiB) Downloaded 780 times
Evo 7 JDM 2001 Stock.hex
(256 KiB) Downloaded 794 times
japerformance
Postby tachyon » Thu Jul 05, 2007 5:01 pm
hahah,...
hi, I have the same problem too... I didnt open but it doesnt show the graph.
input values are out of range. I didnt try to flash my evo7 to evo 8, it didnt work out. :cry:
tachyon
Postby sub7 » Sun Jul 08, 2007 10:56 pm
Your xml file way too small. Try mine.
98640014.xml
(17.04 KiB) Downloaded 695 times
sub7
Postby burgers » Wed Jul 11, 2007 7:42 am
Hi
This is my latest xml, there is some experimental stuff so take it easy with things that you don't normally see in your ROM maps.
MB
98640014.xml
(23.85 KiB) Downloaded 753 times
burgers
Postby erggy » Mon Aug 20, 2007 7:23 am
hi burgers,
just wondering if i can just try to use ur custom XML to tune my JDM evoVII? It uses the same ROM definition but not sure if I would face any ROM writing/reading issues if I were to use ur XML file w/o touching any 'custom stuff' yet?
I noticed that you have leanspool start and stop rpm already.. wanted to use that function. Can u also shared w/ me of you have successfully disabled leanspool on ur evo7? thanks
erggy
hi burgers,
erggy
Postby burgers » Mon Dec 24, 2007 3:04 am
Hi
Sorry haven't checked here in ages, I just uploaded an updated xml to the post above. Yes lean spool start and stop are working as expected, you should be fine with this xml if your ROM ID is 98640014, as usual though, use at your own risk and use the correct tool to monitor your engines paramiters.
MB
burgers
