2007 WRX MT - A8DK100X
Postby wage0052 » Fri Feb 02, 2007 6:40 am
You can modify that field using enginuity. The stock "throttle reduction" is set to 149 mph.
wage0052
Postby bad » Thu Mar 29, 2007 1:24 am
Jeramie wrote:The 07 is identical to the 06 as far as I can tell so far. osecuroms.org has a stg1 06 posted. It just needs to be copied over to the 07 base rom and that should be a pretty good starting point.
which xml file have u used to read the rom file?
bad
Postby FlimFlamMan1 » Thu Apr 26, 2007 6:26 pm
FWIW, here is my Stock 07 WRX-TR Rom.
Stock 07_4_26_FFM.hex
(1 MiB) Downloaded 588 times
FlimFlamMan1
Postby McTune » Thu Jun 21, 2007 7:51 am
Just curious if anyone has had any luck re-flashing an 07 WRX yet. Eng. recognizes the map but when I load it into ECUFlash to write to the ECU the properties are all over the place. Using ECUFlash 1.30
McTune
Postby FlimFlamMan1 » Thu Jun 21, 2007 11:06 am
Yeah I and many others have successfully flashed an 07 wrx. I havent heard of your particular problem before. I'll see what I can find out when I have more time. Maybe one of the pro's will chime in soon to help out.
FlimFlamMan1
Postby McTune » Tue Jun 26, 2007 10:55 am
Are you following the steps as outlaid previously in this post and using v. 1.28 of Ecuflash or?
McTune
