Cannot Run ECUFlash 1.3
Postby s2p2 » Mon Mar 19, 2007 6:28 am
Hey guys
I have uninstalled 1.29a, the 2 drivers.
Installed 1.3 but it cannot run.
I am not sure what went wrong. Anyone faced the same issue and resolved it?
s2p2
Postby zigzagzok » Mon Mar 19, 2007 6:50 am
i had to uninstall everything
ecuflash1.29a + the FTDI serial bus + Tactrix CDM packages
4 items in total
then installed 1.3
zigzagzok
Postby cboles » Mon Mar 19, 2007 10:02 am
what problem did you have if you did not uninstall before installing 1.30? nothing has changed about the drivers...
Postby s2p2 » Mon Mar 19, 2007 2:46 pm
for me, i just would not run at all
s2p2
Postby Freon » Wed Mar 21, 2007 4:51 pm
This is the same issue I'm seeing. I am also on Windows 2000 SP4 on my laptop (s2p2 is on Win2k sp4 per another thread). I was fine with everything up to 1.29a, though I lost my copy of it so I can't roll back. I have 1.28 but it crashes seemingly no matter what I do now with a generic application error. It used to work fine.
Ecuflash simply will not start. Hourglass comes up for a split second, that's it. Not to be found running in task manager. No error message.
I've pretty thoroughly uninstalled things, made sure the actual drivers are gone from various locations in the windows install directory as well, rebooted, reinstalled, and soforth. I spent a few hours on it. I wonder if anyone with Win2k has it working.
It runs fine on my desktop and a SFF system I hauled out to my garage to test. Both of those are running XP. I successfully flashed my car with the SFF system. The SFF has never had any Ecuflash version on it so it was a clean 1.30 install. My desktop has had a few versions of Ecuflash. I've never gone through an uninstall process on it. I've also never plugged in the Tactrix cable into the desktop.
Postby blue.taxi » Wed Mar 21, 2007 5:42 pm
OK for this reason I will try on another notebook... see will it read my ecu.
thks..
blue.taxi
Postby s2p2 » Wed Mar 21, 2007 6:25 pm
Freon wrote:This is the same issue I'm seeing. I am also on Windows 2000 SP4 on my laptop (s2p2 is on Win2k sp4 per another thread). I was fine with everything up to 1.29a, though I lost my copy of it so I can't roll back. I have 1.28 but it crashes seemingly no matter what I do now with a generic application error. It used to work fine.
I am looking for another win2K machine to try too. All my installations on XP works seamlessly. If you need 1.29a, just PM me ur email, still have it with me
s2p2
Postby blue.taxi » Wed Mar 21, 2007 7:13 pm
s2p2,
But my Winxp w/ 1.29a seem cannot read the ECU data....., can this be the ECU block the reading??
blue.taxi
Postby Freon » Wed Mar 21, 2007 9:02 pm
I upgraded my laptop to XP and it is now working. I installed XP (upgrade), tried Ecuflash and it crashed with a generic windows application error. Just reran the installer and it started working with no further reboots, uninstalls, etc.
Postby s2p2 » Wed Mar 21, 2007 10:53 pm
blue.taxi wrote:s2p2,
I have not tried installing 1.29a on a xp. coz i needed 1.3. perhaps i will try when free
s2p2
Postby s2p2 » Wed Mar 21, 2007 10:54 pm
Freon wrote:I upgraded my laptop to XP and it is now working. I installed XP (upgrade), tried Ecuflash and it crashed with a generic windows application error. Just reran the installer and it started working with no further reboots, uninstalls, etc.
problem for me is that the notebook is my company's and i am not allowed to upgrade to xp....
s2p2
Postby blue.taxi » Thu Mar 22, 2007 12:41 am
Later I try will the Ecuflash 1.3 also seem no luck..... :? anyway will try again this time redo the uninstall & manully take out all the cable driver.... then try again..
BTW, I hv another cable which can download the data of the new mini cooper S, can any one in here read the data too??? :wink:
blue.taxi
ECUFLASH 1.3 doesnot run on Windows 2000?
Postby evo8 » Fri Apr 13, 2007 7:25 am
version 1.3 seems not to run on Windows 2000 - installation went fine, after starting the program - clock is there for a while and then nothing happens.....
Any ideas ? I cannot reinstall to Win XP due to my company's IT restrictions.
evo8
Re: ECUFLASH 1.3 doesnot run on Windows 2000?
Postby Jon [in CT] » Fri Apr 13, 2007 7:46 am
evo8 wrote:Any ideas ? I cannot reinstall to Win XP due to my company's IT restrictions.
Do your company's IT restrictions apply to a laptop you own?
Postby evo8 » Fri Apr 13, 2007 11:39 am
May be I wasn't clear - its is a company laptop - not my own.
evo8
