Leaving the Openport cable plugged in - does it draw power?
Postby S54fan » Sun Mar 18, 2007 4:14 am
With engine off, will my Evo battery flatten if I leave it plugged in?
I'm doing so much testing I don't want to damage the plug and socket from repeated use.
Postby Freon » Sun Mar 18, 2007 6:53 am
I leave mine attached on my Subaru. I don't think there should be any problem.
Postby cboles » Mon Mar 19, 2007 10:10 am
It does draw a small amount of current. I wouldn't leave it installed in a car that doesn't get driven regularly. Alternatively, you could rewire the OBD plug to only provide +12 when the car is in an ON key position...
