merchgod wrote:I can probably add your definition to the next release so you'll be able to tune it. I just don't understand why your calid is cut off at 0x2000 and 0xC0000 (reads as "A8DG30 "). Do you think a tuner has messed with your ecu? Sometimes tuners will blank out a portion of the id or add asterisks so either you can't open it with the openecu tools or to identify their work. Or you said it was some prototype ecu?
evoX wrote:Keener2.5 can you tell me exactly what connector did you connect in order to read the rom of the limited edition 07 STi ? because I am having the same problem, reading the rom.
I have connected a jumper on the white connector located left at the driver side near the fuse box, and also the green connectors, with no luck
Ah, the the A2UJ000J ROM image which fixes the 2007 STI "Surge on acceleration between 3000 and 4000 rpm" problem. Nice.ev8siv3 wrote:No probs here. Posted.
This CalID A2UJ000J is mentioned in the thread at http://www.iwsti.com/forums/showthread.php?p=1132716#post1132716, although a zero was dropped from it. The CalId on the 2007 US STI as shipped from the factory was A2UG000J.Freon wrote:Sure that's the fix? Its numbering looks more like a first revision. I'd expect a revision to have something like --100J or --010J, etc.
