Hello, I have a 2002 usdm wrx wagon that is flashed to stage 2 with the XPT map that I bought. my engine mods are: Helix catless DP, invidia 3 inch catback, erz uppipe, perrin foam panel airfilter. I run 5w30 dino oil and change every 3k miles, car has 70 miles on it now. Could you guys take a look at my map and tell me what's going on? I'm getting egt's around 950C at the end of a 3rd gear pull, so I've been driving really softly all the time now. I'm not really sure how to read the logs so I need some help trying to figure out what the problem is. I am going to get an A/F ratio meter sometime to help try and figure out what the problem is and I'd really like to solve this problem so that I can get back out to the track as I don't want to try tracking the car with these problems. The third gear pull is in the last part of the log.
Also these logs were taken with the silencer in, I'm not sure if it will affect things much, but I get high egt's whether or not the silencer is in.
log is taken going slightly uphill.
Thanks!
