Can't get no software to detect the Tactrix Cable
Similar comms issues?
Postby renhoek » Tue Jan 09, 2007 11:19 pm
Hi Prana. Any resolution to this issue? I am also having comms issues & don't have the brains you seem to, to figure it out.
I posted a separate note on the board in the hope someone can help me.
renhoek
Postby cboles » Wed Jan 10, 2007 2:54 pm
Your installation of EcuFlash has a bad set of ROM metadata for one reason or another. Perhaps you have pointed it to a different directory, or have edited an XML file erroneously. In any case, EcuFlash can build a list of possible ROMs type to read from for the read menu, and that is causing the problem, not the cable.
Postby ev8siv3 » Fri Feb 09, 2007 12:57 pm
I think I figured out how to get this working properly.
1. Uninstall ALL occurnaces of EcuFlash, FTDI drivers, OpenPort Drivers, Unplug Cable, etc...
2. Install a copy of EcuFlash 1.28 but DO NOT install the OpenPort Drivers when prompted.
3. Reboot computer.
4. Unzip attached file to a folder on your desktop
5. Place Tactrix cable in the computer
6. When prompted to install driver, select from "Other Location"
7. Install driver from unzipped folder on your desktop
8. Configure COM Port to your liking.
9. Done!
ProperTactrixDrivers.zip
(746.43 KiB) Downloaded 702 times
ev8siv3
Postby byrollSTi » Sun Feb 11, 2007 1:55 pm
ev8siv3 wrote:I think I figured out how to get this working properly.
3. Reboot computer.
9. Done!
Worked for me!!!
thanks
byrollSTi
