Need Help on this e9 ROM
Postby spooky » Mon Dec 25, 2006 9:13 am
Using the latest ecuflash to download the rom image..but can see the parameters on it.
Appreciate if someone can post the xml of this JDM e9 rom image...
Many thanks!
E9.hex
need definition file on this rom image
(512 KiB) Downloaded 818 times
spooky
Postby Tuned by LIM » Wed Dec 27, 2006 11:31 am
just wonder, I never seen 8998-0000 before
which type? year? transmission? of your E9 JDM
Tuned by LIM
Postby spooky » Wed Dec 27, 2006 10:56 pm
5sp, E9 gt, 2006
Tuned by LIM wrote:just wonder, I never seen 8998-0000 before
spooky
Postby S54fan » Thu Dec 28, 2006 4:17 am
Just inherit 88570008 which I made and published on here and see if that works. I can't remember if the number listed is the 9GT I've seen before though.
Postby fil78 » Fri Jan 05, 2007 2:36 pm
'tried with 89280002 (2006 JDM) and it seems OK
cheers
fil78
Postby CJS-IX-SE » Sun Jan 28, 2007 5:04 pm
how do i read this rom? my ecuflash wont let me open it.
CJS-IX-SE
Postby Tuned by LIM » Mon Feb 05, 2007 3:11 pm
CJS-IX-SE wrote:how do i read this rom? my ecuflash wont let me open it.
download 88570008.xml or 82980002.xml files from another thread and put on rometadata folder.
when open this rom just choose inherit from new xml file above.
Tuned by LIM
Postby spooky » Mon Feb 12, 2007 12:34 am
do u need to ammend the flash method in the 88570008.xml from mitsukernel to mitsukernelocp once u inherit the 88570008? i noticed this 88570008 flash method is "mitsukernel" only.
Please advise...
spooky
Postby S54fan » Mon Feb 12, 2007 2:55 pm
My 88570008 uses "mitsukernelocp" to read and write my JDM/UK IX.
Some earlier definitions I did for earlier versions of ECUflash seemed to need "evo" changed to mitsukernel or similar.
I don't understand what is going on and just fiddle with it until it works ;)
Postby R. Mutt » Tue Jan 15, 2008 4:52 am
I made a definition for this ROM:
89980000.zip
(2.01 KiB) Downloaded 380 times
R. Mutt
Postby Mellon » Thu Feb 14, 2008 8:09 am
R. Mutt wrote:I made a definition for this ROM:
my ecuflash bombs out if I use this definition with 1.29a or 1.34 :(
still looking for a solution for this ROM
Mellon
Postby todd-w » Thu Feb 14, 2008 8:56 am
yhpm
todd-w
Postby Mellon » Thu Feb 14, 2008 12:19 pm
todd-w wrote:
yhpm
thanks replied, no luck yet
Mellon
Postby todd-w » Fri Feb 15, 2008 1:41 am
try this one in ecuflash2
80920002.xml
(11.36 KiB) Downloaded 667 times
todd-w
Postby Mellon » Fri Feb 15, 2008 6:24 am
with 1.29 that definition crashes the program when you open it
with 1.34 I can start the application without a crash, I can open the ROM but I only see the "ROM Info" , no fuel/timing/vvt etc..
I tried to different ROM's including the one you sent me privately, same thing.
I even tried a fresh separate install of 1.34, no luck.
suggestions?
Mellon
