evoscan error!!!!!!!!
Postby eiu » Wed Dec 27, 2006 9:57 am
hello, when i open evoscan i have this message:
Error: Invalid Evaluation Expression in your Data.xml file or invalid data received.
RequestID: 07
Eval Expression: -0.0003893*30*30*30+0.08056*30*30-6.5226*30+315.73
Error: Input string was not in a correct format.
Info: Datalogger Ended.
help me please!!!!
eiu
Postby Evo4Mad » Sun Jan 07, 2007 12:22 pm
I think it is look for x
that actual dataitem value. I can change EvoScan to ignore this error in v0.98
Postby bobik » Wed Jan 24, 2007 12:04 pm
I have the same problem,
eiu did you find any solution ?
bobik
Postby Evo4Mad » Thu Jan 25, 2007 2:59 pm
yep some countries don't accept the . as a decimal placeholder, change them all the eval expressions in the data.xml file to use a comma ,
the next version of EvoScan will be able to support countries that use a comma for decimal representation.
Postby Settdimisti » Thu Jul 19, 2007 9:48 pm
Guys please help i got the same error
I use v.99. What can i do about this?
thanks!
Settdimisti
Postby antons.bungis » Fri Jul 20, 2007 1:11 pm
try Start-Settings-Control Panel-Regional & Language settings- Customize- Change decimal symbol from (,) coma to (.) dot :wink:
antons.bungis
Postby Evo4Mad » Sat Jul 21, 2007 3:32 am
EvoScan v1.0 fixes this, so that regional setting change is now no longer required.
Postby dimitrisSTI » Sun Jul 22, 2007 5:21 am
Thanks guys
dimitrisSTI
