Unable to read properly my ecu images!
Postby jrsimon27 » Tue Jan 16, 2007 12:22 pm
i have a 2005 evo8 rs jdm model
iam using ecuflash but when i download it using a 2005usdm i only see certain tables on my ROM i will attach it so that someone can help me
thanks
evo8jdm.hex
(256 KiB) Downloaded 723 times
jrsimon27
Postby S54fan » Tue Jan 16, 2007 3:31 pm
Don't have xml for this, the 8 and 8 MR JDM I made don't work.
RPM limit works from the 8 FQ300 xml I posted, but I'll need to do some disassembly of it tomorrow for you to find the others.
Postby MalibuJack » Tue Jan 16, 2007 4:26 pm
This Definition file should work...
There's a thread somewhere around here, where the thread starter maintains a library of currently known definitions, and posts the link to individual definitions, and he attaches a compressed collection of all known files. This definition was not my creation..
This is for ECUID 97470001 which is your ECU according to the ROM's internal ECUID. I loaded it sucessfully with this definition in ECUFlash 1.29a (build 1.29.906) And it appears that a majority of the tables look to be correct.. A few of the knock sensor filters need the XY axis swapped in the definition, but nobody should be touching those anyway.
This looks to be a EDM Rom not JDM
97470001.xml
(21.23 KiB) Downloaded 768 times
MalibuJack
Postby S54fan » Wed Jan 17, 2007 3:20 am
Thanks Jack, pleased to know it isn't another JDM variant to have to hack. Main maps display fine with that xml for me too.
Postby jrsimon27 » Wed Jan 17, 2007 1:44 pm
ok so how do i do to download this xml file and use it to read my tables?
but i guarantee my car is a jdm model my mitsudealear imports them from japan so this is interesting to know!
please help me with is xml file how do i downloaded iam a complete newbie and thanks for all of your help guys!!
jrsimon27
Postby jrsimon27 » Wed Jan 17, 2007 2:04 pm
when i download the image posted by malibujack this is what i see:
it open in another window:
- <rom>
- <romid>
<xmlid>97470001</xmlid>
<internalidhex>97470001</internalidhex>
<make>Mitsubishi</make>
<market>EDM</market>
<model>Lancer</model>
<submodel>EVO 8</submodel>
<year>2005</year>
<flashmethod>mitsukernel</flashmethod>
<memmodel>SH7052</memmodel>
</romid>
<scaling name="AFR" units="AFR" toexpr="14.7*128/x" frexpr="14.7*128/x" format="%.1f" min="8" max="20" inc="0.1" storagetype="uint8" endian="big" />
<scaling name="AirFlow16" units="g/s" toexpr="x*600/65536" frexpr="x*65536/600" format="%.1f" min="0" max="600" inc="1" storagetype="uint16" endian="little" />
<scaling name="AirFlow8" units="g/s" toexpr="x*321/256" frexpr="x*256/321" format="%.1f" min="0" max="321" inc="1" storagetype="uint8" endian="little" />
<scaling name="BatteryVoltage" units="V" toexpr="x*75/1024" frexpr="x*1024/75" format="%.2f" min="0" max="18.75" inc="0.5" storagetype="uint16" endian="little" />
<scaling name="BoostBar" units="bar" toexpr="x/93.7" frexpr="x*93.7" format="%.2f" min="0" max="2.7" inc="0.05" storagetype="uint8" endian="little" />
<scaling name="BoostBar16" units="bar" toexpr="x/1372.2" frexpr="x*1372.2" format="%.2f" min="0" max="2.7" inc="0.05" storagetype="uint16" endian="little" />
<scaling name="BoostError" units="%" toexpr="x*5/32-20" frexpr="(x+20)*32/5" format="%.1f" min="-20" max="20" inc="0.5" storagetype="uint16" endian="little" />
<scaling name="DynamicBoost" units="%" toexpr="(x-128)/2" frexpr="x*2+128" format="%.1f" min="-64" max="63.5" inc="0.5" storagetype="uint8" endian="little" />
<scaling name="EnrichmentAdj" units="%" toexpr="x/128" frexpr="x*128" format="%.2f" min="0" max="2" inc="0.05" storagetype="uint8" endian="little" />
<scaling name="Hex16" units="hex" toexpr="x" frexpr="x" format="%04X" min="0" max="65535" inc="1" storagetype="uint16" endian="little" />
<scaling name="Hex8" units="hex" toexpr="x" frexpr="x" format="%02X" min="0" max="255" inc="1" storagetype="uint8" endian="little" />
<scaling name="ISCVSteps" units="Steps" toexpr="x" frexpr="x" format="%.0f" min="0" max="255" inc="1" storagetype="uint8" endian="little" />
<scaling name="ISCVSteps16" units="Steps" toexpr="x" frexpr="x" format="%.0f" min="0" max="255" inc="1" storagetype="uint16" endian="little" />
<scaling name="InjectorLatency" units="ms" toexpr="x*0.024" frexpr="x/0.024" format="%.3f" min="0" max="4" inc="1" storagetype="uint8" endian="big" />
<scaling name="InjectorScaling" units="cc/min" toexpr="29241/x" frexpr="29241/x" format="%.0f" min="1" max="1000" inc="10" storagetype="uint16" endian="little" />
<scaling name="Load" units="%" toexpr="x*10/32" frexpr="x*32/10" format="%.0f" min="0" max="300" inc="1" storagetype="uint16" endian="little" />
<scaling name="Load16" units="units" toexpr="x*5/8" frexpr="x*8/5" format="%.1f" min="0" max="100" inc="1" storagetype="uint16" endian="little" />
<scaling name="Load8" units="%" toexpr="x*5/8" frexpr="x*8/5" format="%.1f" min="0" max="160" inc="1" storagetype="uint8" endian="little" />
<scaling name="LoadBoost" units="%" toexpr="x*5/4" frexpr="x*4/5" format="%.0f" min="0" max="319" inc="1" storagetype="uint8" endian="little" />
<scaling name="MAFsize" units="units" toexpr="39044/x" frexpr="39044/x" format="%.0f" min="1000" max="5000" inc="1" storagetype="int16" endian="little" />
<scaling name="RPM" units="RPM" toexpr="x*1000/256" frexpr="x*256/1000" format="%.0f" min="0" max="11000" inc="50" storagetype="uint16" endian="little" />
<scaling name="RPM8" units="RPM" toexpr="x*125/16" frexpr="x*16/125" format="%.0f" min="0" max="2000" inc="50" storagetype="uint8" endian="little" />
<scaling name="RPMLimit" units="RPM" toexpr="7500000/x" frexpr="7500000/x" format="%.0f" min="0" max="9000" inc="60" storagetype="uint16" endian="little" />
<scaling name="RPMStatLimit" units="units" toexpr="x*31.25" frexpr="x/31.25" format="%.0f" min="0" max="9000" inc="31.25" storagetype="uint16" endian="little" />
<scaling name="RPMTarget" units="RPM" toexpr="x*125/16" frexpr="x*16/125" format="%.0f" min="0" max="2000" inc="50" storagetype="uint16" endian="little" />
<scaling name="Temp" units="Celsius" toexpr="x-40" frexpr="x+40" format="%.0f" min="-40" max="215" inc="1" storagetype="uint16" endian="little" />
<scaling name="ThrottleVoltage" units="V" toexpr="x*5/256" frexpr="x*256/5" format="%.2f" min="0" max="5" inc="0.05" storagetype="uint8" endian="little" />
<scaling name="Time" units="ms" toexpr="x*25" frexpr="x/25" format="%.0f" min="0" max="1.63838e+06" inc="25" storagetype="uint16" endian="little" />
<scaling name="TimeSec" units="s" toexpr="x/10" frexpr="x*10" format="%.1f" min="0" max="25.5" inc="0.1" storagetype="uint16" endian="little" />
<scaling name="Timing" units="degrees" toexpr="x" frexpr="x" format="%.0f" min="-61" max="61" inc="1" storagetype="int8" endian="big" />
<scaling name="ValveTiming" units="degrees" toexpr="72-x*0.6" frexpr="(72-x)/0.6" format="%.1f" min="0" max="30" inc="0.6" storagetype="uint8" endian="big" />
<scaling name="VehicleSpeed" units="km/h" toexpr="x*2" frexpr="x/2" format="%.0f" min="0" max="510" inc="1" storagetype="uint16" endian="little" />
<scaling name="VehicleSpeed8" units="units" toexpr="x*2" frexpr="x/2" format="%.0f" min="0" max="510" inc="1" storagetype="uint8" endian="little" />
<scaling name="Volts16" units="Volts" toexpr="x*5/256" frexpr="x*256/5" format="%.2f" min="0" max="5" inc="0.05" storagetype="uint16" endian="little" />
<scaling name="WGDuty" units="%" toexpr="x/2" frexpr="x*2" format="%.1f" min="0" max="100" inc="0.5" storagetype="uint8" endian="little" />
<scaling name="uint16" units="units" toexpr="x" frexpr="x" format="%.0f" min="0" max="65535" inc="1" storagetype="uint16" endian="little" />
<scaling name="uint8" units="units" toexpr="x" frexpr="x" format="%.0f" min="0" max="255" inc="1" storagetype="uint8" endian="big" />
- <table name="High Octane Fuel Map" category="Fuel" address="35bd" type="3D" swapxy="true" scaling="AFR">
<table name="Load" address="5778" type="X Axis" elements="18" scaling="Load" />
<table name="RPM" address="5750" type="Y Axis" elements="15" scaling="RPM" />
</table>
- <table name="Low Octane Fuel Map" category="Fuel" address="36d7" type="3D" swapxy="true" scaling="AFR">
</table>
- <table name="High Octane Ignition Map 1" category="Timing" address="3b85" type="3D" swapxy="true" scaling="Timing">
<table name="Load" address="57d6" type="X Axis" elements="19" scaling="Load" />
<table name="RPM" address="57a6" type="Y Axis" elements="19" scaling="RPM" />
</table>
- <table name="Low Octane Ignition Map 1" category="Timing" address="3cf9" type="3D" swapxy="true" scaling="Timing">
</table>
- <table name="Injector Battery Voltage Latency Compensation" category="Fuel" address="3970" type="2D" scaling="InjectorLatency">
<table name="Battery Voltage" address="56b8" type="Y Axis" elements="7" scaling="BatteryVoltage" />
</table>
<table name="Rev Limit" category="Limits" address="158c" type="1D" scaling="RPMLimit" />
<table name="Stationary Rev Limit" category="Limits" type="1D" scaling="RPMStatLimit" />
- <table name="Accel Enrichment" category="Fuel" address="3a14" type="2D" scaling="EnrichmentAdj">
<table name="RPM" address="54ea" type="Y Axis" elements="15" scaling="RPM" />
</table>
<table name="Boost Control Load Offset" category="Turbo" address="1a6e" type="1D" scaling="Load16" />
- <table name="Turbo Boost Error Correction" category="Turbo" address="42ec" type="2D" scaling="DynamicBoost">
<table name="Boost Error" address="5a3e" type="Y Axis" elements="17" scaling="BoostError" />
</table>
- <table name="Boost Desired Engine Load # 1" category="Turbo" address="43b4" type="2D" scaling="Load8">
<table name="RPM" address="57a6" type="Y Axis" elements="16" scaling="RPM" />
</table>
- <table name="Boost Desired Engine Load # 2" category="Turbo" address="43ca" type="2D" scaling="Load8">
</table>
- <table name="Boost Desired Engine Load # 3" category="Turbo" address="43e0" type="2D" scaling="Load8">
</table>
- <table name="Boost Desired Engine Load # 4" category="Turbo" type="2D" scaling="Load8">
</table>
- <table name="Max Wastegate Duty # 1" category="Turbo" address="4304" type="2D" scaling="WGDuty">
</table>
- <table name="Max Wastegate Duty # 2" category="Turbo" address="4330" type="2D" scaling="WGDuty">
</table>
- <table name="Max Wastegate Duty # 3" category="Turbo" address="4346" type="2D" scaling="WGDuty">
</table>
- <table name="Max Wastegate Duty # 4" category="Turbo" address="4372" type="2D" scaling="WGDuty">
</table>
- <table name="Open Loop Load # 1" category="Fuel" address="3824" type="2D" scaling="Load8">
<table name="RPM" address="545c" type="Y Axis" elements="15" scaling="RPM" />
</table>
- <table name="Open Loop Load # 2" category="Fuel" address="383a" type="2D" scaling="Load8">
</table>
- <table name="Open Loop Throttle Low Load" category="Fuel" address="3856" type="2D" scaling="ThrottleVoltage">
</table>
- <table name="Open Loop Throttle High Load" category="Fuel" address="386c" type="2D" scaling="ThrottleVoltage">
</table>
<table name="IC Relay Timer ON Mode Switch Time" category="Misc" address="247c" type="1D" scaling="TimeSec" />
<table name="IC Relay Timer Control RPM" category="Misc" address="247e" type="1D" scaling="RPMStatLimit" />
- <table name="IC Relay Timer Control Water Temp" category="Misc" address="2480" type="2D" scaling="Temp">
- <table name="Condition" type="Static Y Axis" elements="2">
<data>Hi</data>
<data>Lo</data>
</table>
</table>
<table name="IC Relay Control Vehicle Speed" category="Misc" address="2484" type="1D" scaling="VehicleSpeed" />
<table name="IC Relay Control EV" category="Misc" address="247a" type="1D" scaling="Load" />
- <table name="IC Relay Timer Time" category="Misc" address="2488" type="2D" scaling="TimeSec">
<data>On</data>
<data>Off</data>
</table>
</table>
- <table name="IC Relay Timer Control Judgement" category="Misc" address="2496" type="2D" scaling="Volts16">
<data>Hi</data>
<data>Lo</data>
</table>
</table>
<table name="IC Relay Timer Air Temp" category="Misc" address="249a" type="1D" scaling="Temp" />
- <table name="Desired ISCV intial step position with AC off-Neutral" category="Idle" address="40da" type="2D" scaling="ISCVSteps">
<table name="Engine Temp" address="5916" type="Y Axis" elements="8" scaling="Temp" />
</table>
- <table name="Desired ISCV intial step position with AC off-Drive" category="Idle" address="40e8" type="2D" scaling="ISCVSteps">
</table>
- <table name="Desired ISCV intial step position with AC on-Neutral" category="Idle" address="40f6" type="2D" scaling="ISCVSteps">
</table>
- <table name="Desired Idle RPM-Neutral" category="Idle" address="40be" type="2D" scaling="RPM8">
</table>
- <table name="Desired Idle RPM-Drive" category="Idle" address="40cc" type="2D" scaling="RPM8">
</table>
- <table name="Desired Idle RPM with AC on" category="Idle" address="186c" type="2D" scaling="RPMTarget">
- <table name="Condition" type="Static Y Axis" elements="4">
<data>Neut</data>
<data>Drive</data>
<data>Neut</data>
<data>Drive</data>
</table>
</table>
- <table name="High Intake Air Temp Idle Speed Target" category="Idle" address="2208" type="2D" scaling="RPMTarget">
<data>AC Off</data>
<data>AC On</data>
</table>
</table>
- <table name="High Intake Air Temp ISCV Increase" category="Idle" address="220c" type="2D" scaling="ISCVSteps16">
<data>AC Off</data>
<data>AC On</data>
</table>
</table>
<table name="Min Coolant Temp for Closed Loop" category="Fuel" address="15aa" type="1D" scaling="Temp" />
- <table name="Boost Limit" category="Turbo" address="3814" type="2D" scaling="LoadBoost">
<table name="RPM" address="5e64" type="Y Axis" elements="9" scaling="RPM" />
</table>
- <table name="Speed Limit" category="Limits" address="158e" type="2D" scaling="VehicleSpeed">
<data>On</data>
<data>Off</data>
</table>
</table>
<table name="Boost Enhancement (Anti-Lag) Start RPM" category="Turbo" address="1680" type="1D" scaling="RPMStatLimit" />
<table name="Injector Scaling" category="Fuel" address="1506" type="1D" scaling="InjectorScaling" />
- <table name="Wastgate Solenoid Activation RPM" category="Turbo" address="1a66" type="2D" level="1" scaling="RPMStatLimit">
<data>Reactivate On</data>
<data>Reactivate Off</data>
<data>Deactivate On</data>
<data>Deactivate Off</data>
</table>
</table>
<table name="Boost Cut Delay Timer" category="Turbo" address="159a" type="1D" level="4" scaling="Time" />
- <table name="MAF Scaling" category="Fuel" address="3506" type="2D" level="3" scaling="AirFlow8">
<table name="Load" address="5668" type="Y Axis" elements="21" scaling="uint16" />
</table>
- <table name="MAF Smoothing Table" category="Fuel" address="3522" type="2D" level="3" scaling="AirFlow8">
</table>
- <table name="Air Temperature Compensation" category="Fuel" address="353e" type="2D" level="3" flipy="true" scaling="uint8">
<table name="Degrees" address="594a" type="Y Axis" elements="8" scaling="Temp" />
</table>
- <table name="Barometric Pressure Compensation" category="Fuel" address="3551" type="3D" level="3" swapxy="true" scaling="BoostBar">
<table name="Atmosphere Pressure" address="5656" type="X Axis" elements="4" scaling="Load16" />
<table name="RPM" address="569c" type="Y Axis" elements="9" scaling="RPM" />
</table>
- <table name="Idle Stepper Look-up Table" category="Idle" address="41fd" type="3D" level="2" scaling="ISCVSteps">
<table name="Throttle Position" address="594a" type="X Axis" elements="8" scaling="uint16" />
<table name="RPM" address="5964" type="Y Axis" elements="27" scaling="RPM" />
</table>
- <table name="Knock Sensor Filter Map 1" category="Timing" address="4701" type="3D" level="4" swapxy="true" scaling="uint8">
<table name="TAR" address="5b1c" type="X Axis" elements="12" scaling="Load16" />
<table name="RPM" address="5afc" type="Y Axis" elements="11" scaling="RPM" />
</table>
- <table name="Knock Sensor Filter Map 2" category="Timing" address="4791" type="3D" level="1" swapxy="true" scaling="uint8">
</table>
- <table name="Knock Sensor Filter Map 3" category="Timing" address="4821" type="3D" level="1" scaling="uint8">
</table>
- <table name="Knock Sensor Filter Map 4" category="Timing" address="48b1" type="3D" level="1" scaling="uint8">
</table>
- <table name="Knock Sensor Filter Map 5" category="Timing" address="4941" type="3D" level="1" swapxy="true" scaling="uint8">
</table>
- <table name="Knock Sensor Filter Map 6" category="Timing" address="49d1" type="3D" level="1" swapxy="true" scaling="uint8">
</table>
- <table name="Knock Sensor Filter Map 7" category="Timing" address="4ccb" type="3D" level="1" swapxy="true" scaling="uint8">
</table>
- <table name="Knock Sensor Filter Map 8" category="Timing" address="4d5b" type="3D" level="1" swapxy="true" scaling="uint8">
</table>
- <table name="Knock Sensor Filter Map 9" category="Timing" address="4deb" type="3D" level="1" swapxy="true" scaling="uint8">
</table>
- <table name="Knock Sensor Filter Map 10" category="Timing" address="4e7b" type="3D" level="1" swapxy="true" scaling="uint8">
</table>
- <table name="Knock Sensor Filter Map 11" category="Timing" address="4f0b" type="3D" level="1" swapxy="true" scaling="uint8">
</table>
- <table name="Knock Sensor Filter Map 12" category="Timing" address="4f9b" type="3D" level="1" swapxy="true" scaling="Timing">
</table>
<table name="Init Code" category="Misc" address="3ffcc" type="1D" level="1" scaling="Hex16" />
<table name="Immobilizer" category="Misc" address="3ffce" type="1D" level="3" scaling="Hex16" />
- <table name="MAF Sensor Filtering" category="Fuel" address="1508" type="2D" level="3" scaling="uint16">
- <table name="Load" type="Static Y Axis" elements="2">
<data>Hi</data>
<data>Lo</data>
</table>
</table>
<table name="MAF Size" category="Fuel" address="150c" type="1D" level="3" scaling="AirFlow16" />
<table name="Min Temp for Full Boost Control" category="Turbo" address="21fe" type="1D" level="3" scaling="Temp" />
- <table name="Boost Control Limiting Vehicle Speed" category="Turbo" address="2202" type="2D" level="3" scaling="VehicleSpeed8">
<data>On</data>
<data>Off</data>
</table>
</table>
<table name="Boost Enhancement (Anti-lag) Stop RPM" category="Turbo" address="1682" type="1D" level="3" scaling="RPMStatLimit" />
- <table name="Boost Enhancement (Anti-lag) Table" category="Fuel" address="3b66" type="2D" level="1" scaling="ThrottleVoltage">
<table name="RPM" address="5738" type="Y Axis" elements="7" scaling="RPMStatLimit" />
</table>
- <table name="Boost Enhancement Enrich/Enlean (Anti-lag) Map" category="Fuel" address="3e6d" type="3D" level="1" swapxy="true" scaling="AFR">
</table>
- <table name="Boost Enhancement Adv/Ret Map 1 (Anti-lag)" category="Timing" type="3D" level="1" swapxy="true" scaling="Timing">
<table name="RPM" address="57a6" type="Y Axis" elements="20" scaling="RPM" />
</table>
- <table name="Boost Enhancement Adv/Ret Map 2 (Anti-lag)" category="Timing" type="3D" level="1" swapxy="true" scaling="Timing">
</table>
</rom>
what do i do???????
thanks
jrsimon27
Postby jrsimon27 » Wed Jan 17, 2007 2:23 pm
i did it thanks to both know i can see my tables thanks a lot guys sorry for all the confusion :D :D :D :D :D :D :D :D :D :D :D :D
but why would mitsu japan send me a car with a edm ecu
here is my chasis number or vin #JMYSNCT9A5U000532
buy the Y its a jdm model right?
thanks guys
jrsimon27
Postby MalibuJack » Wed Jan 17, 2007 4:48 pm
I think its just that the first person who created this definition entered EDM because he thought it was a euro spec car. As lon s it works, its not important nor does it affect anything relevent.
MalibuJack
Postby jrsimon27 » Wed Jan 17, 2007 8:06 pm
what i can see is that my maps are very aggressive timing and fuel
WOW!
Why would japan do this maps so aggressive?
jrsimon27
Postby Rotawerx » Wed Jan 17, 2007 9:47 pm
Their fuel is that much better. And perhaps emissions not so strict?
Rotawerx
Postby Tuned by LIM » Fri Jan 19, 2007 12:52 pm
JMYSNCT9Axx-xxxxxx was mean made in Japan by Mitsubishi for export market
Japan Domestic Market just CT9A-xxxxxx only !
Tuned by LIM
