First off, I’m not a programmer or engineer. My BS degree is in the computer engineering technology area, but it’s been over 12 years since I’ve worked in that field. Needless to say, I’m real rusty, but can fumble my way around if forced. I’ve designed and programmed a few PIC based control circuits for some simple projects I’ve worked on in the past few years, so I’m a little bit familiar with the general technology.
I’ll probably pull out my ECU this weekend to get this information, but want to get a jump start if anybody knows the answer already. I have a 2005 USDM STi & from my ODBII scanner I pulled this info: CAL = A2ZJB10J & AD3A101D; CVN = F118A080.
Does anybody know the answers to the following questions?
1) Does the ECU utilize discrete components for processing, static memory, volatile memory, and I/O?
2) What is the “ROM” (is it an EEPROM, Micro Controller, some sort of CMOS flash memory chip, etc.)?
3) What is the “ROM’s” manufacturer & part number?
4) Does anyone have manufacturer data sheets on these things?
4) Has anyone programmed any other functionality for the ECU besides the standard tuning parameter changes?
That about does it for now.
Thanks,
Chad
