by cboles » Thu Nov 03, 2005 5:59 pm
Thanks.
Here is what I need for right now - The first 5 actions I could use some fairly stock icons for, but it would be nice if all of the icons have a consistent look. A 48x48x24bit PNG file would be a good starting point for each icon. I can scale those down for different resolutions the app might need. I've attached an icon I though was interesting for "write to flash", but really I would be happy with any set of visually pleasing icons that aren't too "loud".
* EcuFlash application icon
* Icons for the following actions
- Open an existing ROM file
- Save the ROM under a new name
- Save the log file under a new name
- Exit the application
- Show the application's About box
- Read from ECU's flash memory
- Write currently loaded ROM image to ECU's flash memory
- Test write currently loaded ROM image to ECU's flash memory
- Compare currently loaded ROM image to ECU's flash memory
- Simulate ECU using currently loaded ROM image for ECU's flash memory
- Attachments
- burn.png (1.85 KiB) Viewed 3286 times
