Map needed for 2002 Airtrek Turbo
Postby koolkiwikat » Wed Jan 10, 2007 2:20 am
Hi People, Can someone help? Im trying to find a map for my Airtrek 2002 Turbo which is based on a detuned EVO 7 GT-A setup....cant find anything online....
Cheers!
Master.hex
My attached rom
(256 KiB) Downloaded 791 times
koolkiwikat
Postby monsta11 » Wed Jan 10, 2007 10:59 pm
Done- main maps that you will use are done
89970010.xml
(2.26 KiB) Downloaded 824 times
monsta11
Postby Rotawerx » Thu Jan 11, 2007 12:18 am
Hey...... I just noticed you guys are kiwi's too... There a few of us here using these? Sorry for off topic :)
Rotawerx
Postby JamAir » Wed Jan 17, 2007 12:53 pm
Hi,
I downloaded the map for the 2002 ATR and it looks good. However I noticed that in the map it includes 8354008 however I can find that map anywhere.
Is that the right include map? If so does anyone have a copy of that map?
Cheers,
Dave
JamAir
Update
Postby JamAir » Wed Jan 17, 2007 1:00 pm
I know the engine is a evo 7 so I changed the include to the EVO7Base. The Hex loaded right up.....But being the cautious type I don't want to do anything until I can confirm that that is the right map.
Thanks in advance for the help.
JamAir
Postby monsta11 » Sun Jan 28, 2007 10:20 pm
as long as the info in the tables doesnt look random- you are ready to rock.
monsta11
Need a map for my airtrek tomai ecu.
Postby yee » Fri May 04, 2007 4:29 am
Hi Monsta,
Can you help on this.
Many Thanks,
Yee
tomei airtrek.hex
(512 KiB) Downloaded 735 times
yee
Postby Keiran » Fri May 04, 2007 7:16 pm
yikes!! hope you don't blow the engine with these crappy maps
Keiran
XMLs
Postby mtcavity » Fri May 04, 2007 8:34 pm
Here is the FULL definition for the 02 Airtrek!
Some new maps, so turn on your user levels to development.
Will post the others soon.
2002 Mitsubishi Airtrek JDM (AT) [89970010] ROM-XML.rar
(98.28 KiB) Downloaded 463 times
mtcavity
Re: Need a map for my airtrek tomai ecu.
Postby mtcavity » Fri May 04, 2007 9:22 pm
Please post year of your vehicle for reference please.
Full defintions viewable using Developmet user level.
2004 Mitsubishi Airtrek-Tomei JDM (AT) [89970017] ROM-XML.rar
(191.78 KiB) Downloaded 475 times
mtcavity
Postby yee » Fri May 04, 2007 10:04 pm
Hi mtcavity,
Many thanks for your help, my Airtrek was on year 2004.
Bty, how to turn on the user level to development??? :oops: :oops: :oops:
yee
User level.
Postby mtcavity » Sat May 05, 2007 5:09 pm
Here.
User Level.JPG (51.12 KiB) Viewed 9382 times
mtcavity
Thank you very much !!!
Postby yee » Sun May 06, 2007 3:42 am
Thanks mtcavity!!!! :D :D :D
yee
Postby diablo2184 » Thu May 24, 2007 7:14 pm
how are these maps for the Airtrek Turbo? What kind of power are you guys making on this map? any knock? i have one in jamaica and wanted to flash it if possible.
diablo2184
Be Careful with the latest
Postby FQ-Airtrek » Fri May 25, 2007 12:14 am
I did a chk using the 89970017 using the Tomei ECU hex file. Noticed plenty of errors. Maybe mtcavity can correct me if I am wrong..
- The base is EVO9 (unsure whether the tomei ecu was read/open using EVo 9 kernel?)
- Target AFR is 14.0 (not the normal 14.7)
- Max wastegate duty at 127.5% (max is 100%)
- Timing data are totally crazy
Just use the xml for reference for now. I cannot use this xml to open my .bin files as I noticed the base is using EVO9 mine was EVO7.
I am currently using 89970010 (read using EVO7/8 kernel) and the readings are accurate and stable. I have reflashed my Airtrek many times. First to remove the speedcut, boost cut then to tune the fuel map and iginition timing. Performance wise is better and easier to manage with ecuflash. Previous I used SAFC2 and difficult to tune car, running lean with high exhaust temp. I have already sold my SAFC. Better get a logger like scantech or evoscan, exhaust temp, boost meter to test out the settings.
FQ-Airtrek
